  3. Random Reboot issue while voxl-streamer is running
4 Posts 3 Posters 858 Views 1 Watching
  • Inhan KangI Offline
    Inhan KangI Offline
    Inhan Kang
    When running our algorithm or doing voxl-streamer while connected to a microhard, the drone is experiencing a random reboot. This issue is difficult to see when connected via wifi (station mode). When the drone reboots, it is disconnected from qgc and reconnected to qgc about 1 minute later. I think they had the same problem, can you tell me how they solved it?
    We are using 1.1.2 sdk. And Microhard is pMDDL G2
    ModeratorM 1 Reply Last reply
    • Inhan KangI Inhan Kang
      @Inhan-Kang while on the ground, can you place a fan near by? you are likely overheating. In the air, you should be fine
      Inhan KangI 1 Reply Last reply
      • ModeratorM Moderator
        Inhan KangI Offline
        Inhan KangI Offline
        Inhan Kang
        @Moderator I checked voxl-inspect-cpu and it looks fine.
          M Offline
          M Offline
          msberk
          @Inhan-Kang Did you ever resolve this issue? We may have a similar one. Ruled out power issues already by running straight off a powerful 5V supply. It does not reboot though, just goes dark and stops responding over ADB or over the network (we are using Doodle).
