  3. About mipi extension flex cable(M0036) version
3 Posts 3 Posters 810 Views 2 Watching
  • I Offline
    I Offline
    iksk
    Hi support team.
    I have a two version mipi extension flex cable(M0036).
    Above cable is a newer (got in 2023) and backside of the connectors are without a shield, bellow cable is a older (maybe got in 2021) and backside of the connectors are with a shield.
    I tried test change two cable with bellow conditions:
    • Board: VOXL2
    • Connected in: J7-upper with VOXL 2 Dual Camera Adapter(M0084),
    • Image sensor: IMX412(M0061)
    Newer cable is a clash voxl-camera-server some times, but older cable is stable.
    I want to use a stable one, even if more expensive, slightly heavy.
    Can I get a older version cables?
    VinnyV 1 Reply Last reply
    • I iksk
      Hi support team.
      • Board: VOXL2
      VinnyV Online
      VinnyV Online
      Vinny
      HI @iksk
      That stiffener on the older units is not a shield. It's just floating metal (stainless steel). We have since moved away from all metal stiffeners due to electrical shorting risks in tight drone assemblies, and all new flexes have the laminate backers now. The laminate is slightly thicker at 0.8mm instead of 0.2mm.
      If you are seeing performance issues between the two, it is purely coincidence and likely more result of manufacturing variance or handling resulting in degradation. We have built and tested thousands of the new ones and there are no stability differences between them.
      Hope that helps.
      • Gary HolmgrenG Offline
        Gary Holmgren
