  2. VOXL SDK and Software
  3. how to stop microdds-agent from running?
ros
2 Posts 2 Posters 945 Views 1 Watching
  • Kyuhyong YouK Offline
    Kyuhyong You
    wrote on last edited by Kyuhyong You
    As soon as I install voxl-ros2-foxy, I see topics being published
    $ ros2 topic list
    /fmu/collision_constraints/out
    /fmu/debug_array/in
    /fmu/debug_key_value/in
    /fmu/debug_value/in
    /fmu/debug_vect/in
    /fmu/manual_control_setpoint/in
    /fmu/offboard_control_mode/in
    /fmu/onboard_computer_status/in
    /fmu/optical_flow/in
    /fmu/position_setpoint/in
    /fmu/position_setpoint_triplet/in
    /fmu/sensor_combined/out
    /fmu/telemetry_status/in
    /fmu/timesync/in
    /fmu/timesync/out
    /fmu/trajectory_bezier/in
    /fmu/trajectory_setpoint/in
    /fmu/trajectory_waypoint/out
    /fmu/vehicle_attitude/out
    /fmu/vehicle_command/in
    /fmu/vehicle_command_ack/out
    /fmu/vehicle_global_position/out
    /fmu/vehicle_local_position/out
    /fmu/vehicle_local_position_setpoint/in
    /fmu/vehicle_mocap_odometry/in
    /fmu/vehicle_odometry/out
    /fmu/vehicle_offboard_setpoints/in
    /fmu/vehicle_setpoints/in
    /fmu/vehicle_status/out
    /fmu/vehicle_trajectory_bezier/in
    /fmu/vehicle_trajectory_waypoint/in
    /fmu/vehicle_trajectory_waypoint_desired/out
    /fmu/vehicle_visual_odometry/in
    /gimbal_attitude
    /mission_command
    /mission_command_ack
    /mission_status
    /parameter_events
    /physical_state
    /rosout
    /set_vehicle_id
    /stick_command
    /timesync_status
    /vehicle_command
    /vehicle_status
    I didn't even installed voxl-microdds-agent, voxl-mpa-to-ros2
    How can I let voxl stop sending these message?
    I just want to run the agent myself.
    • Kyuhyong YouK Kyuhyong You
      $ ros2 topic list
      /fmu/debug_array/in
      /fmu/debug_value/in
      /fmu/debug_vect/in
      /fmu/timesync/in
      /fmu/timesync/out
      /gimbal_attitude
      /mission_command
      /mission_status
      /parameter_events
      /physical_state
      /rosout
      /set_vehicle_id
      /stick_command
      /timesync_status
      /vehicle_command
      /vehicle_status
      @Kyuhyong-You Take a look at the file /usr/bin/voxl-px4-start. That is the file that starts all of the PX4 drivers, modules, etc. Look for the microdds_client start -t udp -h 127.0.0.1 -p 8888 line and comment that out.
