    voxl2 rangefinder (lw20)
    1865
    • R
      relevinsky
      I need to connect my rangefinder (LW20) to the VOXL2 board using connector J19 (by I2C) to the PX4 flight controller. What configurations should I make in QGroundControl to receive the "Distance Sensor" message in the Mavlink Analyze tab?
      Thank you.
      • Eric KatzfeyE
        Eric Katzfey ModalAI Team @relevinsky
        @relevinsky The driver for that is not currently built into the VOXL2 PX4 firmware. You would need to add that to your build.
        voxltesterV 1 Reply Last reply Reply Quote 0
        • voxltesterV
          voxltester @Eric Katzfey
          @Eric-Katzfey
          I am wondering if rangefinders can be used for VOXL2.
          Specifically, I have LW20/C rangefinder and tried to setup on VOXL2 by referring to https://docs.modalai.com/voxl2-D0015/. But it is not working.
          One more thing is voxl-configure-rangefinders package.
          https://gitlab.com/voxl-public/voxl-sdk/services/qrb5165-rangefinder-server
          Can you explain what this one is for?
          I tried to use it by running voxl-configure-rangefinders, it is not working..
          I hope you provide the instruction to install the rangefinder on the VOXL2.
          Thank you.
          Eric KatzfeyE 2 Replies Last reply Reply Quote 0
          • Eric KatzfeyE
            Eric Katzfey ModalAI Team @voxltester
            @voxltester In order to use the LW20 with i2c interface you would need to add that driver to your build (e.g. in boards/modalai/voxl2-slpi/default.px4board). And then you would need to start that driver in the startup script (e.g. in boards/modalai/voxl2/target/voxl-px4-start).
            • Eric KatzfeyE
              @voxltester The voxl-configure-rangefinders refers to range finders connected to the apps processor outside of px4. If you use that then the voxl-rangefinder-server will communicate to px4 with mavlink messages to indicate distance.
              • voxltesterV
                @Eric-Katzfey
                Thank you for your quick answer.
                Eric, on my VOXL2 flight deck, I cannot find board folder...
                Please refer to the version info of my VOXL2.
                voxl2:/$ voxl-version
                system-image: 1.7.1-M0054-14.1a-perf-nightly-20231025
                kernel:       #1 SMP PREEMPT Thu Oct 26 03:25:38 UTC 2023 4.19.125
                hw platform:  M0054
                mach.var:     1.0
                voxl-suite:   1.1.3-1
                Packages:
                Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.1/binary-arm64/
                Last Updated: 2024-05-07 20:27:28
                voxltesterV tomT 2 Replies Last reply Reply Quote 0
                • voxltesterV
                  voxltester @voxltester
                  @Eric-Katzfey
                  One more question,
                  Is there any other way to use LW20 instead of i2c?
                  • tomT
                    tom admin @voxltester
                    @voxltester This is what he is referring to as the boards folder: https://github.com/modalai/px4-firmware/tree/b5c45bb232afc6a936b8349f4fa0be1efeb17707/boards
                    • voxltesterV
                      voxltester @tom
                      @tom
                      THank you for the info.
                      I am using VOXL2 flight deck... I never touched the PX4....
                      What I found just before is /etc/modalai/voxl-px4.conf
                      I edited DISTANCE_SENSOR=LIGHTWARE_SF000, then I was able to see PX4 parameter SENS_EN_SF0X in QGC. I set it as LW20/c..
                      But I cannot see the rangefinder data in QGC MAVLink Inspector...
                      • Eric KatzfeyE
                        @voxltester Again, LW20 is not in the px4 build. Until you rebuild px4 with that driver you cannot use it within px4. So, you have 2 choices. Rebuild PX4 and try to get LW20 working within PX4 or take a look at the source code for voxl-rangefinder-server and see if you can add support for LW20 into that. It currently supports the vl53l1x rangefinder. Perhaps you can just switch to that rangefinder model? Otherwise the source code it here: https://gitlab.com/voxl-public/voxl-sdk/services/qrb5165-rangefinder-server
