  3. VOXL2 Mini internal PX4 is taking more than 100% CPU Usage
voxl-2-mini
4 Posts 2 Posters 1.5k Views 1 Watching
  • T Offline
    T Offline
    Trinadh
    My Voxl 2 Mini is taking More than 100% cpu , and temperatures are going so up while running the PX4.
    Voxl 2 mini is taking nearly - 550mA current at 2S battery.
    If we are running other services except PX4 , the temperature was normal
    • T Trinadh
      @Trinadh Is this with SDK 1.0.0? Is this VOXL2 mini in a drone? If so, what is the configuration (e.g. What peripherals like GPS, RC, ESC, etc. are attached)?
      T 1 Reply Last reply
        T Offline
        T Offline
        Trinadh
        @Eric-Katzfey , Hi we are using VOXL2 Mini SDK 1.0.0 - i am not attached GPS, RC, ESC. any other peripherals, the output is the same, and PX4 is running at 140% as well.
        I have tried using ESC also but the output is the same.
        The module is heating up crazy!!!
        • T Trinadh
          @Trinadh Can you edit the file /etc/modalai/voxl-px4.conf and set GPS=NONE, RC=EXTERNAL, POWER_MANAGER=NONE, DISTANCE_SENSOR=NONE, and OSD=DISABLE. After updating that file and rebooting does the CPU utilization change at all?
