Voxl-streamer with UVC
I have an original VOXL flight. I am attempting to stream a uvc camera stream with voxl streamer, but am having no success. I have looked over your RTSP streaming page as well as uvc and cannot find the solution. I have attached pictures for details below. Thank you in advance for any help
@Brandon-Wightman If you start voxl-uvc-server running and then
ls -l /run/mpa/camdo you see the pipe listed there? Are you running SDK 0.9.5? -
ls -l /run/mpa/camdo you see the pipe listed there? Are you running SDK 0.9.5?@Eric-Katzfey Here is what I got back
@Brandon-Wightman Can you upgrade to SDK 0.9.5?
