    How to connect VOLX2 mini to LTE modem????
    VOXL 2 Mini
    • J
      Jskim
      Hello, regarding the VOXL 2 Mini :
      1. Currently, the VOXL2+Doodle Lab modem is being used on a fixed-wing drone.
        I'm trying to connect LTE to VOXL2 mini.
        Please tell me the connection method.
      2. The website says USB 3 Add On Connectivity: WiFi, 5G, 4G/LTE, Microhard, but I don't know how to connect it.
      3. How is it possible to connect the LTE Module to the VOXL 2 Mini? The standard Sierra LTE module does not have the same connectors.
      JS, Kim
      • tomT
        tom admin @Jskim
        @Jskim
        It would be very similar to voxl2, except you can use the J3 usb port that is directly on voxl2-mini. It would require a custom cable at this time.
        • J
          Jskim @tom
          @tom
          Thanks, Tom....
          • VinnyV
            Vinny ModalAI Team @Jskim
            Hi @Jskim
            This one for data: https://docs.modalai.com/cable-datasheets/#mcbl-00080
            and this one for a custom splice into the power supply: https://docs.modalai.com/cable-datasheets/#mcbl-00017
            Hope that helps!
            • J
              Jskim @Vinny
              @Vinny
              Thank you so much.
              Kim,
              • D dan64 referenced this topic on
