  2. VOXL SDK and Software
  3. CMake errors on open example
4 Posts 2 Posters 1.1k Views 2 Watching
  • S Offline
    S Offline
    shlee853
    I'm trying to build april-tag-detect examples for opencv on VOXL.
    Actually this examples is based on opencv 3.4, but, I updated version to 4.2.
    https://gitlab.com/voxl-public/core-libs/voxl-opencv
    It fails on build because of missing f package.
    yocto:~/opencv/examples/april-tag-detect$ cmake CMakeLists.txt
    -- The C compiler identification is GNU 4.9.3
    -- The CXX compiler identification is GNU 4.9.3
    -- Check for working C compiler: /usr/bin/cc
    -- Check for working C compiler: /usr/bin/cc -- works
    -- Check for working CXX compiler: /usr/bin/c++
    -- Check for working CXX compiler: /usr/bin/c++ -- works
    CMake Error at CMakeLists.txt:4 (find_package):
      By not providing "FindOpenCV.cmake" in CMAKE_MODULE_PATH this project has
      asked CMake to find a package configuration file provided by "OpenCV", but
      CMake did not find one.
      Could not find a package configuration file provided by "OpenCV" with any
      of the following names:
        OpenCVConfig.cmake
        opencv-config.cmake
      Add the installation prefix of "OpenCV" to CMAKE_PREFIX_PATH or set
      "OpenCV_DIR" to a directory containing one of the above files.  If "OpenCV"
      provides a separate development package or SDK, be sure it has been
      installed.
    -- Configuring incomplete, errors occurred!
    See also "/home/root/opencv/examples/april-tag-detect/CMakeFiles/CMakeOutput.log".
    Could you please let me know advice to find opencv package on VOXL?
    thanks,
      4.5 is hosted here
      http://voxl-packages.modalai.com/stable/
      S 1 Reply Last reply
      • Chad SweetC Chad Sweet
        4.5 is hosted here
        S Offline
        S Offline
        shlee853
        wrote on last edited by shlee853
        @Chad-Sweet I'm not compiling opencv libraries.
        as you know above scripts, I has some errors on building examples for opencv.
        I think it can't find FindOpenCV.cmake file during compiling.
          This cmake file has a good example of finding OpenCV libs using cmake
          https://gitlab.com/voxl-public/core-libs/libmodal_exposure/-/blob/master/library/CMakeLists.txt
