    Termal cam to connect
    • Mariano GOMEZ PLAZAM
      Mariano GOMEZ PLAZA
      We have in mind to use the Seeker dron to make an inspection in an indoor space. In order to do this, we need to connect a thermal cam (20g), which has an USB type C connector.
      Can we plug it into the perception module?
      Thanks&Regards,
      Mariano.
      • ModeratorM
        Moderator ModalAI Team @Mariano GOMEZ PLAZA
        @Mariano-GOMEZ-PLAZA have you looked at this documentation? https://docs.modalai.com/voxl-uvc-flir/#overview
          Mariano GOMEZ PLAZA
          @Dev Team, thank you for your answer.
          Is Seeker drone equipped with a VOXL board to connect a Flir Boson or Lepton cam through an USB UVC interface? If not, which VOXL board should we acquire? or which other products should we consider?
          We need to make the purchase but first, we need to know if we will be able to connect Flir Boson o Lepton cam directly with no development tasks.
          Thank you in advance.
