  3. Left/right cameras appear to be reversed
3 Posts 2 Posters 770 Views
  • A Offline
    afdrus
    Hello everyone,
    I am trying to setup a drone with voxl2 and dual stereo on the front of the drone and on the side of the drone. When I try to calibrate the stereo cameras on the side of the drone however I find the following error:
    Calibrating Extrinsics
    4 frames will be processed
    R
    [0.9999053202420889, 0.01070168208593433, -0.008650118617524936;
     -0.0103011892164794, 0.9989299071531981, 0.04508798172051345;
     0.009123379433737689, -0.04499460629269533, 0.9989455687635205]
    T
    [0.0807117010366965;
     0.0001046958105907691;
     0.003971263355485772]
    Re-projection error reported by stereoCalibrate: 0.377810
    Detected horizontal stereo pair
    Distance between cameras: -0.0807
    Extrinsics Calibration Failed
    left/right cameras appear to be reversed
    How can I solve the issue? I copied the cable management from the sentinel configuration so I doubt that it is a HW issue
    James StrawsonJ 1 Reply Last reply
    • A afdrus
      Hello everyone,
      R
      T
      James StrawsonJ Offline
      James Strawson
      @afdrus
      in /etc/modalai/voxl-camera-server.conf you will see the following segment for the stereo pairs,
      			"type":	"ov7251",
      			"name":	"stereo",
      			"enabled":	true,
      			"camera_id":	1,
      			"camera_id_second":	2,
      If you swap the ID numbers for camera_id and camera_id_second it will reverse the left and right cameras in the stereo stream.
      Best,
      James
      A 1 Reply Last reply
        @afdrus
        			"type":	"ov7251",
        			"name":	"stereo",
        			"enabled":	true,
        			"camera_id":	1,
        Best,
        James
        afdrus
        @James-Strawson Thanks for the reply! Now I am facing a new issue though, after I swapped the camera ids the calibration of the extrinsics is asking me to move the checkboard in only three locations instead of four, as a result the reprojection error keeps being high, is this a bug?
        Result of the new extrinsics:
        R
        [-0.2178154138909582, 0.5612314553199155, 0.7984833742984259;
         0.6516188344157804, -0.5254512170251917, 0.5470776116433248;
         0.7266012249550162, 0.6394687420712871, -0.2512576124371861]
        T
        [-0.5933205685053882;
         -0.3699353785761611;
         0.8991646361380521]
        Re-projection error reported by stereoCalibrate: 71.628572
        Distance between cameras: 0.5933
        exceeded allowable max reprojection error:  0.5
        voxl-camer-server with ids already swapped, the stereo in question is stereo_rear,
        	"version":	0.1,
        	"cameras":	[{
        			"name":	"tracking",
        			"enabled":	true,
        			"frame_rate":	30,
        			"type":	"ov7251",
        			"camera_id":	2,
        			"ae_desired_msv":	60,
        			"ae_exposure_period":	1,
        			"ae_gain_period":	1
        			"name":	"hires",
        			"enabled":	true,
        			"frame_rate":	30,
        			"type":	"imx214",
        			"camera_id":	3,
        			"preview_width":	640,
        			"preview_height":	480,
        			"snapshot_width":	3840,
        			"snapshot_height":	2160
        			"name":	"stereo_front",
        			"enabled":	true,
        			"frame_rate":	30,
        			"type":	"ov7251",
        			"camera_id":	0,
        			"camera_id_second":	1,
        			"independent_exposure":	false,
        			"ae_gain_period":	1
        			"name":	"stereo_rear",
        			"enabled":	true,
        			"frame_rate":	30,
        			"type":	"ov7251",
        			"camera_id":	4,
        			"camera_id_second":	5,
        			"ae_gain_period":	1
