    Downgrading from 1.0.0 to 0.9.5 issues
    • Abdullah01A
      Abdullah01
      I am facing an issue with my drone. In the beginning I upgrade my VOXL2 from 0.9.5 SDK where it was working perfectly without any issue.
      I upgraded the system to 1.0.0 SDK, but there was a problem that I am using I/O board where it is not supported with 1.0.0 SDK.
      So, I had to downgrade the system to 0.9.5, and here where all the problem started.
      I downloaded the 0.9.5 SDK and followed the steps of installation, and restored all the date that I backed-up before the upgrading.
      and now the drone keeps wobbling every time I try to fly it even after tuning the PID, but nothing changed.
      So, is there any solution for it?
      and when the 1.0.0 SDK is it going to support I/O board?
      Is it even possible to downgrade the SDK, and this is why I am facing these issues?
      Thank you
      • Eric KatzfeyE
        Eric Katzfey ModalAI Team @Abdullah01
        @Abdullah01 What are you using the I/O board for? Just RC?
        Abdullah01A 1 Reply Last reply Reply Quote 0
        • Abdullah01A
          Abdullah01 @Eric Katzfey
          @Eric-Katzfey
          I am using it for RC and for ESCs are connected to the I/O board
          • Abdullah01A
            Abdullah01
            Also, when the I/O board for voxl2 1.0.0 SDK are going to support it?
            • Eric KatzfeyE
              @Abdullah01 We are in the final testing stages for our 1.0.1 release which will offer initial support for M0065 when used only for SBUS RC. The next step will be adding PWM output for ESC / Servo and we are still in development of that.
              • Abdullah01A
                @Eric-Katzfey
                hello,
                is there any update for the new version?
                Untill know I can't fly my voxl2 drone, I upgrade the sdk to 1.0.0 and tried to downgrade it to 0.95 but I could not fly it, there was issues with the I/O board.
                is it possible to downgrade the SDK? and if yes how to do it?
                thank you
                • Eric KatzfeyE
                  @Abdullah01 There has been some progress but it is taking longer than expected. We are actively working on all of it.
