  3. IMX 678 IMX 412 LED Meaning
image-sensor
2 Posts 2 Posters 658 Views
  • sspillerS Offline
    sspillerS Offline
    sspiller
    Both the IMX678 and IMX412 have a green status LED on the back that flashes once it is "running".
    This is what we are seeing:
    IMX412: short flash, then green LED remains on while running / RTSP streaming
    IMX678: short flash, then 4 second green LED, 4 seconds LED off, repeat
    We do see RTSP streams with both cameras but often they cut out and trying to start with the LED status to debug, also knowing what we should see on the LED is helpful for mfg techs to confirm functionality.
    VinnyV 1 Reply Last reply
    • sspillerS sspiller
      VinnyV Offline
      VinnyV Offline
      Vinny
      Hi @sspiller
      This LED, D6, is an indicator that all power supplies for the board are ON (and GOOD) and the image sensor is OUT OF Reset.
      When you see it toggling OFF, it implies the VOXL/VOXL 2 is holding the image sensor in reset.
