Need 3D Models for
I need the following two 3D models:- VOXL 2 GPS / Mag / RC Module
- Image Sensor 4k High-resolution for VOXL
(10x10x16mm) (MSU-M0024)
Bill
Bell Helicopter
Bill
Bell Helicopter
Hi @BillatBell
Apologies no one replied to you yet. Our forum extensions are broke and I do not get notified anymore of new posts, so unless I go searching for them, I will never see them. Hopefully we fix that soon!
In any event, for the GPS/Mag module, that is an accessory from Holybro, so we do not own the models.
I did find one version on Grabcad you can explore...
Caution, this is an external link, and we do offer any guarantees on this:
https://grabcad.com/library/holybro-pixhawk-4-neo-m8n-gps-1As far as the PCB unit in there, that is our design. We refer to it as M0094. It's a very simple PCB. Here is that 3D step file for you: https://storage.googleapis.com/modalai_public/modal_drawings/M0094_SPEKTRUM_BIND_CABLE_REVA_FINAL(-1_MAIN)-10-15-21.step
and then we just use clear heatshrink over it to keep it protected.For the M0024 image sensor, the module is something we spec and buy, so we do not own source 3D models, but we have had many customers make their own using the 2D data we post here: https://docs.modalai.com/M0024/#m0024-1-drawings
We also provide our full Voxl-cam 3D model, which has some various parts in it, including some of these image sensors that might give you a jump-start: https://docs.modalai.com/voxl-cam-datasheet/Hope that helps!
Hi @BillatBell
@Vinny - Thanks for all the links and help!
