  3. 3D Models
  4. Need 3D Models for
Need 3D Models for
Scheduled Pinned Locked Moved 3D Models
3 Posts 2 Posters 1.5k Views
  • B Offline
    B Offline
    BillatBell
    I need the following two 3D models:
    1. VOXL 2 GPS / Mag / RC Module
    2. Image Sensor 4k High-resolution for VOXL® (10x10x16mm) (MSU-M0024)
      Bill
      Bell Helicopter
    VinnyV 1 Reply Last reply
    • B BillatBell
        Bill
        Bell Helicopter
      Hi @BillatBell
      Apologies no one replied to you yet. Our forum extensions are broke and I do not get notified anymore of new posts, so unless I go searching for them, I will never see them. Hopefully we fix that soon!
      In any event, for the GPS/Mag module, that is an accessory from Holybro, so we do not own the models.
      I did find one version on Grabcad you can explore...
      Caution, this is an external link, and we do offer any guarantees on this:
      https://grabcad.com/library/holybro-pixhawk-4-neo-m8n-gps-1
      As far as the PCB unit in there, that is our design. We refer to it as M0094. It's a very simple PCB. Here is that 3D step file for you: https://storage.googleapis.com/modalai_public/modal_drawings/M0094_SPEKTRUM_BIND_CABLE_REVA_FINAL(-1_MAIN)-10-15-21.step
      and then we just use clear heatshrink over it to keep it protected.
      For the M0024 image sensor, the module is something we spec and buy, so we do not own source 3D models, but we have had many customers make their own using the 2D data we post here: https://docs.modalai.com/M0024/#m0024-1-drawings
      We also provide our full Voxl-cam 3D model, which has some various parts in it, including some of these image sensors that might give you a jump-start: https://docs.modalai.com/voxl-cam-datasheet/
      Hope that helps!
      B 1 Reply Last reply
      • VinnyV Vinny
        Hi @BillatBell
        Hope that helps!
        B Offline
        B Offline
        BillatBell
        @Vinny - Thanks for all the links and help!
