  2. VOXL Accessories
  3. Image Sensors
  4. IMX678 M0143 Driver not recognized on SDK 1.0.0
Scheduled Pinned Locked Moved Image Sensors
5 Posts 2 Posters 748 Views
  • Davon PrewittD Offline
    Davon Prewitt
    I am on the VOXL 2 MINI. I used voxl-configure-cameras 8 to create a config for the IMX678 (M0143) to use voxl-camera-server. I get the following errors.
    Camera Configuration: 8
    [ERROR] Your system image is too old to support the new camera driver structure
    [ERROR] Plese update to a system image newer than May 14 2023
    I am already flashed to the latest SDK (1.0.0). Is there a workaround?
    • ModeratorM Offline
      wrote on last edited by Moderator
      Hi Davon,
      Have you loaded the image from 7/12/23 - https://developer.modalai.com/asset/10
      Davon PrewittD 1 Reply Last reply
      • ModeratorM Moderator referenced this topic on
        Hi Davon,
        Davon Prewitt
        wrote on last edited by Davon Prewitt
        @Moderator Hello. I have flashed the new drivers and voxl-configure-cameras provided me the right drivers and config. No luck getting the camera server to run though. I tried running the configuration on part M0135 interposer.
        Driver info
        system-image: 1.6.2-M0104-14.1a-perf
        kernel: #1 SMP PREEMPT Fri May 19 22:53:15 UTC 2023 4.19.125
        hw version: M0104
        voxl-suite: 1.0.0
        no current network connection
        voxl-camera-server output
        sensor type: imx678
        isEnabled: 1
        camId: 0
        camId2: -1
        fps: 30
        en_preview:          0
        pre_width:           640
        pre_height:          480
        pre_format:          nv21
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   2048
        large_video_height:  1536
        en_snapshot:         1
        snap_width:          3840
        snap_height:         2160
        ae_mode:             isp
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
        Starting Camera: hires
        Segmentation fault:
        Fault thread: voxl-camera-ser(tid: 3066)
        Fault address: 0x5658e6a6cc
        Address not mapped.
        Segmentation fault
        I have done some more digging and it would appear that HAL3 does not see my IMX678. After running voxl-camera-server -s snd -l, the LED on the camera is on, but not being recognized.
        • Davon PrewittD Davon Prewitt
          Driver info
          hw version: M0104
          voxl-suite: 1.0.0
          sensor type: imx678
          isEnabled: 1
          camId: 0
          camId2: -1
          fps: 30
          en_preview:          0
          pre_width:           640
          pre_height:          480
          pre_format:          nv21
          en_small_video:      1
          en_large_video:      1
          en_snapshot:         1
          snap_width:          3840
          snap_height:         2160
          ae_mode:             isp
          standby_enabled:     0
          decimator:           1
          Segmentation fault:
          Address not mapped.
          Segmentation fault
          Davon Prewitt
          @Moderator Hello again, please advise. I have used voxl-configure-cameras to setup voxl-camera-server to read frames. No luck on my various IMX678 camera modules nor interposers using SDK 1.0.0. The HAL module doesn't seem to recognize the presence of a camera module when calling voxl-camera-server -s. Is there something else i need to do?
            Please see app note here
