  3. Recommended bulk capacitance used for the VDC_5V_LOCAL_USB rail for a USB 3.0 device?
Scheduled Pinned Locked Moved VOXL 2 and VOXL 2 Mini
2 Posts 2 Posters 482 Views
  • ModeratorM Offline
    Do you have a recommended bulk capacitance used for the VDC_5V_LOCAL_USB rail for a USB 3.0 device? I experienced a brownout issue when connecting a USB 3.0 ethernet adapter and I'm trying to figure out what caused it.
    VinnyV 1 Reply Last reply
    • ModeratorM Moderator
      VinnyV Offline
      VinnyV Offline
      Vinny
      @Moderator
      That port is capable of providing 2A at 5V from a SW controlled GPIO (GPIO_157).
      I'm surprised you would experience a brown-out from a USB to ETH adapter.
      On Voxl2, we provide a 10uF and a 1uF cap right at the 60-pin J3 connector.
      If you are doing a custom adapter, and to meet USB3 specs, you should not need much more capacitance.
      However, if you have a long length before your mating connector, a good 10-22uF would be wise.
      We provide a 100uF cap on all of our USB ports that mate to Voxl2 (M0090 5G Modem Plug-in card, for example), but it is also due to a USB switch to help manage the ON time during enumeration.
      Back to your specific issue, I would double check you are not toggling GPIO_157, or that your connection is solid and not intermittent.
      I cannot find specific ETH dongle power consumption specs online, but it is likely using a LAN7801 or similar type device plus a PHY, which would not exceed more than a few hundred mA combined with magnetics:
      So a brown out does not seem likely here. Even a 500mA USB2 rated device has no issue powering these types of dongles.
