  3. Changes regarding px4 commands
3 Posts 2 Posters 472 Views 1 Watching
  • R Offline
    R Offline
    RiveraDn
    Heya!
    So, I used to rock VOXL2 with the old 0.9.4 Suite. But then I upgraded to the fancy new 1.0.0 Suite. Now I'm trying to figure out how to connect to QGC. Any ideas?
    Cheers.
    • R RiveraDn
      Heya!
      Cheers.
      @RiveraDn In general, I'd run through the following to get you to what you're used to:
      # choose which sku best matches your hardware setup
      voxl-configure-sku -w
      # start all services based on the sku you chose in step 1.
      voxl-configure-mpa
      # modify voxl-mavlink-server's config file to point to your qgc_ip
      vi /etc/modalai/voxl-mavlink-server.conf
      # reboot or power cycle
      adb reboot
      Our docs overhaul is still in process , so thank you for being patient with this
      R 1 Reply Last reply
        voxl-configure-mpa
        adb reboot
        R Offline
        R Offline
        RiveraDn
        @tom Thank you for your response! I'll look forward to the new documentation when it becomes available, thanks for the hard work. Cheers!
