  3. how to access tflite_data published by voxl_mpa_to_ros from local machine?
6 Posts 3 Posters 1.6k Views 1 Watching
  • A Offline
    aashry
    wrote on last edited by aashry
    Hello!
    I'm trying to subscribe to /tflite_data publsihed by voxl_mpa_to_ros node on my local machine by using rostopic echo /tflite_data but I keep getting the following error
    ERROR: Cannot load message class for [voxl_mpa_to_ros/AiDetection]. Are your messages built?
    I think this is happening because it's a custom message type that my computer doesn't know about, which means the message definition of AiDetection should be integrated somewhere, but I'm not sure what to do.
    The following is a screenshot showing the voxl_mpa_to_ros node running on voxl, and trying to echo the published topic from a rosmelodic docker container, installed onboard on the drone, which shows the same error message that I receive when I try to do that from my local machine as well. Please assist.
    Thanks in advance for your help!
    A J 2 Replies Last reply
    • A aashry
      Hello!
      aashry
      @aashry If anyone has any insights or suggestions on how to solve this, please do share. Your help would be much appreciated.
      A 1 Reply Last reply
      • A aashry
        aashry
        @tom can you help me with that, or do you know someone who can help? Thank you so much in advance!
        • A aashry
          @aashry What hardware are you using and what software version are you using?: voxl-version
          • A aashry
            Hello!
            jon
            @aashry Follow this link: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros. Catkin_ws -> src -> msg and you will find AiDetection.msg, which you can use to build a ros custom message package (ROS has a tutorial on it I believe). You can do that in whatever workspace you are working in in your docker container. Once that is built and you source devel/setup.bash, you should be able to echo the topic and if you want to subscribe to it in a node you will need to import the message header similarly to any other message type
              aashry
              @tom sorry for the late reply, I've been distant from work for one week. I'm using m500 drone with the voxl flight deck. Below is the voxl-version output as you requested. I will probably try to follow what @jonathankampia mentioned and see if it works. I will update the thread here accordingly. Thank you guys for your help, appreciate it.
              system-image: 4.0.0
              kernel:       #1 SMP PREEMPT Thu Oct 13 17:57:05 UTC 2022 3.18.71-perf
              hw version:   VOXL
              voxl-suite:   0.9.4
              Packages:
              Repo: http://voxl-packages.modalai.com/dists/apq8096/sdk-0.9/binary-arm64/
              Last Updated: 1970-01-01 00:05:23
              List:
              	apq8096-dfs-server       0.3.1
              	apq8096-imu-server       1.0.3
              	apq8096-libpng           1.6.38-1
              	apq8096-system-tweaks    0.1.3
              	apq8096-tflite           2.8.3-1
              	libapq8096-io            0.6.0
              	libmodal-cv              0.2.3
              	libmodal-exposure        0.0.7
              	libmodal-journal         0.2.1
              	libmodal-json            0.4.3
              	libmodal-pipe            2.6.0
              	libvoxl-cci-direct       0.1.5
              	libvoxl-cutils           0.1.1
              	voxl-camera-calibration  0.2.3
              	voxl-camera-server       1.3.5
              	voxl-cpu-monitor         0.3.0
              	voxl-docker-support      1.2.4
              	voxl-gphoto2-server      0.0.10
              	voxl-jpeg-turbo          2.1.3-4
              	voxl-libgphoto2          0.0.4
              	voxl-libuvc              1.0.7
              	voxl-logger              0.3.4
              	voxl-mavlink             0.1.0
              	voxl-mavlink-server      0.2.0
              	voxl-modem               0.16.1
              	voxl-mongoose            7.7.0-1
              	voxl-mpa-to-ros          0.3.6
              	voxl-mpa-tools           0.7.6
              	voxl-opencv              4.5.5-1
              	voxl-portal              0.4.2
              	voxl-qvio-server         0.8.2
              	voxl-streamer            0.4.1
              	voxl-suite               0.9.4
              	voxl-system-image        4.0-r0
              	voxl-tag-detector        0.0.4
              	voxl-tflite-server       0.3.1
              	voxl-utils               1.2.2
              	voxl-uvc-server          0.1.3
              	voxl-vision-px4          1.4.0
              	voxl-vpn                 0.0.6
