Unable to flash VOXL2 Platform 0.9.5
I am not able to flash the system image it's ending with an error
File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory)
Flash procedure is been performed as given in the docs. Same image is installed in other computer and we were previously able to successfully able to to flash but now same problem is persisting.
below is the complete output:
Please help.
Thanks in advance$ ./install.sh [INFO] adb installed [INFO] fastboot installed ----Starting System Image Flash---- Detected OS: Linux Installer Version: 0.8 Image Version: 1.5.5 [INFO] Found adb device, rebooting to fastboot [INFO] Found fastboot device [WARNING] This system image flash is intended only for the following platform: VOXL2 (m0054) Make sure that the device that will be flashed is correct. Flashing a device with an incorrect system image will lead the device to be stuck in fastboot. Would you like to continue with the VOXL2 (m0054) system image flash? 1) Yes 2) No #? 1 [INFO] Found correct partitions [INFO] Found all required files Done Flashing [----------------------------------------------------------------](100%) rebooting... finished. total time: 0.050s [INFO] Waiting for ADB [INFO] Device ready, version: 1.5.5-M0054-14.1a-perf [INFO] Finished flashing system image! ----Installing Suite---- [INFO] adb installed [INFO] Waiting for device [INFO] Pushing packages to target [ ]( 0%) libmodal-cv_0.2.3_arm64.deb: 1 file pushed. 3.7 MB/s (460480 bytes in 0.119s) [- ]( 2%) libmodal-exposure_0.0.7_arm64.deb: 1 f...shed. 3.4 MB/s (11548 bytes in 0.003s) [-- ]( 4%) libmodal-journal_0.2.1_arm64.deb: 1 fi...ushed. 3.5 MB/s (9416 bytes in 0.003s) [--- ]( 6%) libmodal-json_0.4.3_arm64.deb: 1 file ...shed. 3.9 MB/s (44112 bytes in 0.011s) [----- ]( 8%) libmodal-pipe_2.8.2_arm64.deb: 1 file ...shed. 1.8 MB/s (83540 bytes in 0.044s) [------ ]( 10%) libqrb5165-io_0.1.0_arm64.deb: 1 file ...shed. 2.8 MB/s (10620 bytes in 0.004s) [------- ]( 12%) librc-math_1.3.0_arm64.deb: 1 file pushed. 2.7 MB/s (102816 bytes in 0.036s) [-------- ]( 14%) libvoxl-cci-direct_0.1.5_arm64.deb: 1 ...ushed. 1.6 MB/s (6624 bytes in 0.004s) [---------- ]( 16%) libvoxl-cutils_0.1.1_arm64.deb: 1 file...ushed. 1.3 MB/s (6228 bytes in 0.005s) [----------- ]( 18%) mavlink-camera-manager_0.1.0_arm64.deb...shed. 2.3 MB/s (27072 bytes in 0.011s) [------------ ]( 20%) qrb5165-dfs-server_0.1.0_arm64.deb: 1 ...shed. 1.9 MB/s (14400 bytes in 0.007s) [-------------- ]( 22%) qrb5165-imu-server_0.5.0_arm64.deb: 1 ...shed. 2.4 MB/s (60264 bytes in 0.024s) [--------------- ]( 24%) qrb5165-system-tweaks_0.1.5_arm64.deb:...ushed. 1.7 MB/s (6656 bytes in 0.004s) [---------------- ]( 26%) qrb5165-tflite_2.8.0-2_arm64.deb: 1 fi...d. 5.8 MB/s (11028016 bytes in 1.812s) [----------------- ]( 28%) voxl-bind_0.0.1_arm64.deb: 1 file pushed. 1.9 MB/s (4908 bytes in 0.003s) [------------------- ]( 30%) voxl-camera-calibration_0.2.3_arm64.de...shed. 2.8 MB/s (61816 bytes in 0.021s) [-------------------- ]( 32%) voxl-camera-server_1.3.5_arm64.deb: 1 ...hed. 3.7 MB/s (577380 bytes in 0.150s) [--------------------- ]( 34%) voxl-ceres-solver_1.14.0-9_arm64.deb: ...hed. 5.8 MB/s (835012 bytes in 0.137s) [----------------------- ]( 36%) voxl-cpu-monitor_0.3.0_arm64.deb: 1 fi...shed. 5.2 MB/s (25116 bytes in 0.005s) [------------------------ ]( 38%) voxl-docker-support_1.2.4_arm64.deb: 1...ushed. 3.1 MB/s (7908 bytes in 0.002s) [------------------------- ]( 40%) voxl-eigen3_3.4.0_arm64.deb: 1 file pu...ed. 5.0 MB/s (1013744 bytes in 0.192s) [-------------------------- ]( 42%) voxl-flir-server_0.2.0_arm64.deb: 1 fi...ushed. 3.1 MB/s (8136 bytes in 0.003s) [---------------------------- ]( 44%) voxl-gphoto2-server_0.0.10_arm64.deb: ...shed. 3.4 MB/s (31632 bytes in 0.009s) [----------------------------- ]( 46%) voxl-jpeg-turbo_2.1.3-4_arm64.deb: 1 f...ed. 5.4 MB/s (1150788 bytes in 0.202s) [------------------------------ ]( 48%) voxl-libgphoto2_0.0.4_arm64.deb: 1 fil...ed. 6.0 MB/s (1576804 bytes in 0.249s) [-------------------------------- ]( 50%) voxl-libuvc_1.0.7_arm64.deb: 1 file pushed. 5.2 MB/s (47412 bytes in 0.009s) [--------------------------------- ]( 52%) voxl-logger_0.3.4_arm64.deb: 1 file pushed. 3.1 MB/s (37968 bytes in 0.012s) [---------------------------------- ]( 54%) voxl-mapper_0.1.5_arm64.deb: 1 file pushed. 4.3 MB/s (489984 bytes in 0.108s) [----------------------------------- ]( 56%) voxl-mavlink_0.1.0_arm64.deb: 1 file p...hed. 5.6 MB/s (524696 bytes in 0.089s) [------------------------------------- ]( 58%) voxl-mavlink-server_0.3.0_arm64.deb: 1...shed. 4.0 MB/s (17020 bytes in 0.004s) [-------------------------------------- ]( 60%) voxl-modem_0.16.1_arm64.deb: 1 file pushed. 3.8 MB/s (55996 bytes in 0.014s) [--------------------------------------- ]( 62%) voxl-mongoose_7.7.0-1_arm64.deb: 1 fil...shed. 2.7 MB/s (72336 bytes in 0.025s) [---------------------------------------- ]( 64%) voxl-mpa-tools_0.7.5_arm64.deb: 1 file...shed. 2.8 MB/s (55632 bytes in 0.019s) [------------------------------------------ ]( 66%) voxl-mpa-tools_0.7.6_arm64.deb: 1 file...shed. 3.1 MB/s (55576 bytes in 0.017s) [------------------------------------------- ]( 68%) voxl-mpa-to-ros_0.3.6_arm64.deb: 1 fil...hed. 4.0 MB/s (600464 bytes in 0.144s) [-------------------------------------------- ]( 70%) voxl-nlopt_2.5.0-4_arm64.deb: 1 file p...hed. 6.6 MB/s (331988 bytes in 0.048s) [---------------------------------------------- ]( 72%) voxl-opencv_4.5.5-1_arm64.deb: 1 file ...d. 6.0 MB/s (13574024 bytes in 2.174s) [----------------------------------------------- ]( 74%) voxl-portal_0.5.0_arm64.deb: 1 file pu...ed. 6.1 MB/s (1354408 bytes in 0.213s) [------------------------------------------------ ]( 76%) voxl-px4_1.12.31_arm64.deb: 1 file pushed. 6.1 MB/s (5260228 bytes in 0.828s) [------------------------------------------------- ]( 78%) voxl-px4-imu-server_0.1.2_arm64.deb: 1...shed. 2.9 MB/s (10668 bytes in 0.003s) [--------------------------------------------------- ]( 80%) voxl-qvio-server_0.8.2_arm64.deb: 1 fi...shed. 2.7 MB/s (50156 bytes in 0.018s) [---------------------------------------------------- ]( 82%) voxl-remote-id_0.0.5_arm64.deb: 1 file...shed. 1.9 MB/s (38132 bytes in 0.019s) [----------------------------------------------------- ]( 84%) voxl-streamer_0.4.1_arm64.deb: 1 file ...shed. 5.1 MB/s (40208 bytes in 0.008s) [------------------------------------------------------- ]( 86%) voxl-suite_0.9.5_arm64.deb: 1 file pushed. 1.4 MB/s (1424 bytes in 0.001s) [-------------------------------------------------------- ]( 88%) voxl-tag-detector_0.0.4_arm64.deb: 1 f...ed. 5.9 MB/s (1124512 bytes in 0.182s) [--------------------------------------------------------- ]( 90%) voxl-tflite-server_0.3.1_arm64.deb: 1 ...d. 6.1 MB/s (63432692 bytes in 9.982s) [---------------------------------------------------------- ]( 92%) voxl-utils_1.2.2_arm64.deb: 1 file pushed. 4.9 MB/s (36996 bytes in 0.007s) [------------------------------------------------------------ ]( 94%) voxl-uvc-server_0.1.3_arm64.deb: 1 fil...shed. 4.6 MB/s (11060 bytes in 0.002s) [------------------------------------------------------------- ]( 96%) voxl-vision-px4_1.4.0_arm64.deb: 1 fil...shed. 4.4 MB/s (95500 bytes in 0.021s) [-------------------------------------------------------------- ]( 98%) voxl-voxblox_1.1.3_arm64.deb: 1 file p...hed. 5.5 MB/s (726144 bytes in 0.126s) Done Pushing [----------------------------------------------------------------](100%) dpkg-scanpackages: warning: package voxl-mpa-tools (filename ./voxl-mpa-tools_0.7.6_arm64.deb) is repeat but newer version; used that one and ignored data from ./voxl-mpa-tools_0.7.5_arm64.deb! dpkg-scanpackages: warning: Packages in archive but missing from override file: dpkg-scanpackages: warning: libmodal-cv libmodal-exposure libmodal-journal libmodal-json libmodal-pipe libqrb5165-io librc-math libvoxl-cci-direct libvoxl-cutils mavlink-camera-manager qrb5165-dfs-server qrb5165-imu-server qrb5165-system-tweaks qrb5165-tflite voxl-bind voxl-camera-calibration voxl-camera-server voxl-ceres-solver voxl-cpu-monitor voxl-docker-support voxl-eigen3 voxl-flir-server voxl-gphoto2-server voxl-jpeg-turbo voxl-libgphoto2 voxl-libuvc voxl-logger voxl-mapper voxl-mavlink voxl-mavlink-server voxl-modem voxl-mongoose voxl-mpa-to-ros voxl-mpa-tools voxl-nlopt voxl-opencv voxl-portal voxl-px4 voxl-px4-imu-server voxl-qvio-server voxl-remote-id voxl-streamer voxl-suite voxl-tag-detector voxl-tflite-server voxl-utils voxl-uvc-server voxl-vision-px4 voxl-voxblox dpkg-scanpackages: info: Wrote 49 entries to output Packages file. Get:1 file:/data/voxl-suite-offline-packages ./ InRelease Ign:1 file:/data/voxl-suite-offline-packages ./ InRelease Get:2 file:/data/voxl-suite-offline-packages ./ Release Ign:2 file:/data/voxl-suite-offline-packages ./ Release Get:3 file:/data/voxl-suite-offline-packages ./ Packages Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:3 file:/data/voxl-suite-offline-packages ./ Packages Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:3 file:/data/voxl-suite-offline-packages ./ Packages Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:3 file:/data/voxl-suite-offline-packages ./ Packages [8065 B] Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:3 file:/data/voxl-suite-offline-packages ./ Packages Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:3 file:/data/voxl-suite-offline-packages ./ Packages Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:3 file:/data/voxl-suite-offline-packages ./ Packages Err:3 file:/data/voxl-suite-offline-packages ./ Packages File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory) Reading package lists... Done N: Download is performed unsandboxed as root as file '/data/voxl-suite-offline-packages/./InRelease' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied) E: Failed to fetch file:/data/voxl-suite-offline-packages/./Packages File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory) E: Some index files failed to download. They have been ignored, or old ones used instead. [INFO] Installing packages on target Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package voxl-suite [INFO] Pointing to correct repo /bin/bash: voxl-configure-pkg-manager: command not found [INFO] Done installing voxl-suite ----Installation Completed---- -
Please help.
@Anubhav I've never seen this before, try the following to force a complete wipe and re-flash:
cd voxl2_platform_0.9.5 cd system-image ./flash-system-image.sh -f cd .. cd voxl-suite ./offline-install.sh adb shellHi @tom, Thanks for quick response.
you can see the output below for above procedure. it's not flashing the image completely.
# anubhav @ anubhav-GF63-Thin-9SC in ~/Downloads/voxl2_platform_0.9.5/system-image [22:43:22] $ ./flash-system-image.sh Detected OS: Linux Installer Version: 0.8 Image Version: 1.5.5 [INFO] Found fastboot device [WARNING] This system image flash is intended only for the following platform: VOXL2 (m0054) Make sure that the device that will be flashed is correct. Flashing a device with an incorrect system image will lead the device to be stuck in fastboot. Would you like to continue with the VOXL2 (m0054) system image flash? 1) Yes 2) No #? 1 [INFO] Found correct partitions [INFO] Found all required files Done Flashing [----------------------------------------------------------------](100%) rebooting... finished. total time: 0.050s [INFO] Waiting for ADB [INFO] Device ready, version: 1.5.5-M0054-14.1a-perf [INFO] Finished flashing system image! # anubhav @ anubhav-GF63-Thin-9SC in ~/Downloads/voxl2_platform_0.9.5/system-image [22:45:50] $ cd .. # anubhav @ anubhav-GF63-Thin-9SC in ~/Downloads/voxl2_platform_0.9.5 [22:46:00] $ cd voxl-suite # anubhav @ anubhav-GF63-Thin-9SC in ~/Downloads/voxl2_platform_0.9.5/voxl-suite [22:46:07] $ ./offline-install.sh [INFO] adb installed [INFO] Waiting for device [INFO] Pushing packages to target [ ]( 0%) libmodal-cv_0.2.3_arm64.deb: 1 file pushed. 3.7 MB/s (460480 bytes in 0.118s) [- ]( 2%) libmodal-exposure_0.0.7_arm64.deb: 1 f...shed. 4.1 MB/s (11548 bytes in 0.003s) [-- ]( 4%) libmodal-journal_0.2.1_arm64.deb: 1 fi...ushed. 2.7 MB/s (9416 bytes in 0.003s) [--- ]( 6%) libmodal-json_0.4.3_arm64.deb: 1 file ...shed. 4.2 MB/s (44112 bytes in 0.010s) [----- ]( 8%) libmodal-pipe_2.8.2_arm64.deb: 1 file ...shed. 2.5 MB/s (83540 bytes in 0.031s) [------ ]( 10%) libqrb5165-io_0.1.0_arm64.deb: 1 file ...shed. 2.3 MB/s (10620 bytes in 0.004s) [------- ]( 12%) librc-math_1.3.0_arm64.deb: 1 file pushed. 2.7 MB/s (102816 bytes in 0.037s) [-------- ]( 14%) libvoxl-cci-direct_0.1.5_arm64.deb: 1 ...ushed. 1.4 MB/s (6624 bytes in 0.004s) [---------- ]( 16%) libvoxl-cutils_0.1.1_arm64.deb: 1 file...ushed. 1.2 MB/s (6228 bytes in 0.005s) [----------- ]( 18%) mavlink-camera-manager_0.1.0_arm64.deb...shed. 1.4 MB/s (27072 bytes in 0.019s) [------------ ]( 20%) qrb5165-dfs-server_0.1.0_arm64.deb: 1 ...shed. 1.7 MB/s (14400 bytes in 0.008s) [-------------- ]( 22%) qrb5165-imu-server_0.5.0_arm64.deb: 1 ...shed. 2.3 MB/s (60264 bytes in 0.025s) [--------------- ]( 24%) qrb5165-system-tweaks_0.1.5_arm64.deb:...ushed. 1.2 MB/s (6656 bytes in 0.005s) [---------------- ]( 26%) qrb5165-tflite_2.8.0-2_arm64.deb: 1 fi...d. 6.2 MB/s (11028016 bytes in 1.709s) [----------------- ]( 28%) voxl-bind_0.0.1_arm64.deb: 1 file pushed. 2.9 MB/s (4908 bytes in 0.002s) [------------------- ]( 30%) voxl-camera-calibration_0.2.3_arm64.de...shed. 4.3 MB/s (61816 bytes in 0.014s) [-------------------- ]( 32%) voxl-camera-server_1.3.5_arm64.deb: 1 ...hed. 4.7 MB/s (577380 bytes in 0.117s) [--------------------- ]( 34%) voxl-ceres-solver_1.14.0-9_arm64.deb: ...hed. 6.3 MB/s (835012 bytes in 0.126s) [----------------------- ]( 36%) voxl-cpu-monitor_0.3.0_arm64.deb: 1 fi...shed. 5.0 MB/s (25116 bytes in 0.005s) [------------------------ ]( 38%) voxl-docker-support_1.2.4_arm64.deb: 1...ushed. 4.5 MB/s (7908 bytes in 0.002s) [------------------------- ]( 40%) voxl-eigen3_3.4.0_arm64.deb: 1 file pu...ed. 5.6 MB/s (1013744 bytes in 0.172s) [-------------------------- ]( 42%) voxl-flir-server_0.2.0_arm64.deb: 1 fi...ushed. 2.9 MB/s (8136 bytes in 0.003s) [---------------------------- ]( 44%) voxl-gphoto2-server_0.0.10_arm64.deb: ...shed. 3.3 MB/s (31632 bytes in 0.009s) [----------------------------- ]( 46%) voxl-jpeg-turbo_2.1.3-4_arm64.deb: 1 f...ed. 4.1 MB/s (1150788 bytes in 0.270s) [------------------------------ ]( 48%) voxl-libgphoto2_0.0.4_arm64.deb: 1 fil...ed. 5.9 MB/s (1576804 bytes in 0.254s) [-------------------------------- ]( 50%) voxl-libuvc_1.0.7_arm64.deb: 1 file pushed. 5.0 MB/s (47412 bytes in 0.009s) [--------------------------------- ]( 52%) voxl-logger_0.3.4_arm64.deb: 1 file pushed. 3.1 MB/s (37968 bytes in 0.012s) [---------------------------------- ]( 54%) voxl-mapper_0.1.5_arm64.deb: 1 file pushed. 3.2 MB/s (489984 bytes in 0.144s) [----------------------------------- ]( 56%) voxl-mavlink_0.1.0_arm64.deb: 1 file p...hed. 4.6 MB/s (524696 bytes in 0.108s) [------------------------------------- ]( 58%) voxl-mavlink-server_0.3.0_arm64.deb: 1...shed. 4.0 MB/s (17020 bytes in 0.004s) [-------------------------------------- ]( 60%) voxl-modem_0.16.1_arm64.deb: 1 file pushed. 2.8 MB/s (55996 bytes in 0.019s) [--------------------------------------- ]( 62%) voxl-mongoose_7.7.0-1_arm64.deb: 1 fil...shed. 2.7 MB/s (72336 bytes in 0.026s) [---------------------------------------- ]( 64%) voxl-mpa-tools_0.7.5_arm64.deb: 1 file...shed. 3.6 MB/s (55632 bytes in 0.015s) [------------------------------------------ ]( 66%) voxl-mpa-tools_0.7.6_arm64.deb: 1 file...shed. 2.8 MB/s (55576 bytes in 0.019s) [------------------------------------------- ]( 68%) voxl-mpa-to-ros_0.3.6_arm64.deb: 1 fil...hed. 4.7 MB/s (600464 bytes in 0.122s) [-------------------------------------------- ]( 70%) voxl-nlopt_2.5.0-4_arm64.deb: 1 file p...hed. 4.1 MB/s (331988 bytes in 0.077s) [---------------------------------------------- ]( 72%) voxl-opencv_4.5.5-1_arm64.deb: 1 file ...d. 6.1 MB/s (13574024 bytes in 2.113s) [----------------------------------------------- ]( 74%) voxl-portal_0.5.0_arm64.deb: 1 file pu...ed. 6.6 MB/s (1354408 bytes in 0.194s) [------------------------------------------------ ]( 76%) voxl-px4_1.12.31_arm64.deb: 1 file pushed. 6.2 MB/s (5260228 bytes in 0.808s) [------------------------------------------------- ]( 78%) voxl-px4-imu-server_0.1.2_arm64.deb: 1...shed. 4.6 MB/s (10668 bytes in 0.002s) [--------------------------------------------------- ]( 80%) voxl-qvio-server_0.8.2_arm64.deb: 1 fi...shed. 6.0 MB/s (50156 bytes in 0.008s) [---------------------------------------------------- ]( 82%) voxl-remote-id_0.0.5_arm64.deb: 1 file...shed. 4.4 MB/s (38132 bytes in 0.008s) [----------------------------------------------------- ]( 84%) voxl-streamer_0.4.1_arm64.deb: 1 file ...shed. 3.1 MB/s (40208 bytes in 0.012s) [------------------------------------------------------- ]( 86%) voxl-suite_0.9.5_arm64.deb: 1 file pushed. 1.2 MB/s (1424 bytes in 0.001s) [-------------------------------------------------------- ]( 88%) voxl-tag-detector_0.0.4_arm64.deb: 1 f...ed. 5.8 MB/s (1124512 bytes in 0.185s) [--------------------------------------------------------- ]( 90%) voxl-tflite-server_0.3.1_arm64.deb: 1 ...d. 6.2 MB/s (63432692 bytes in 9.747s) [---------------------------------------------------------- ]( 92%) voxl-utils_1.2.2_arm64.deb: 1 file pushed. 5.1 MB/s (36996 bytes in 0.007s) [------------------------------------------------------------ ]( 94%) voxl-uvc-server_0.1.3_arm64.deb: 1 fil...shed. 3.9 MB/s (11060 bytes in 0.003s) [------------------------------------------------------------- ]( 96%) voxl-vision-px4_1.4.0_arm64.deb: 1 fil...shed. 6.0 MB/s (95500 bytes in 0.015s) [-------------------------------------------------------------- ]( 98%) voxl-voxblox_1.1.3_arm64.deb: 1 file p...hed. 6.0 MB/s (726144 bytes in 0.115s) Done Pushing [----------------------------------------------------------------](100%) dpkg-scanpackages: warning: package voxl-mpa-tools (filename ./voxl-mpa-tools_0.7.6_arm64.deb) is repeat but newer version; used that one and ignored data from ./voxl-mpa-tools_0.7.5_arm64.deb! dpkg-scanpackages: warning: Packages in archive but missing from override file: dpkg-scanpackages: warning: libmodal-cv libmodal-exposure libmodal-journal libmodal-json libmodal-pipe libqrb5165-io librc-math libvoxl-cci-direct libvoxl-cutils mavlink-camera-manager qrb5165-dfs-server qrb5165-imu-server qrb5165-system-tweaks qrb5165-tflite voxl-bind voxl-camera-calibration voxl-camera-server voxl-ceres-solver voxl-cpu-monitor voxl-docker-support voxl-eigen3 voxl-flir-server voxl-gphoto2-server voxl-jpeg-turbo voxl-libgphoto2 voxl-libuvc voxl-logger voxl-mapper voxl-mavlink voxl-mavlink-server voxl-modem voxl-mongoose voxl-mpa-to-ros voxl-mpa-tools voxl-nlopt voxl-opencv voxl-portal voxl-px4 voxl-px4-imu-server voxl-qvio-server voxl-remote-id voxl-streamer voxl-suite voxl-tag-detector voxl-tflite-server voxl-utils voxl-uvc-server voxl-vision-px4 voxl-voxblox dpkg-scanpackages: info: Wrote 49 entries to output Packages file. Get:1 file:/data/voxl-suite-offline-packages ./ InRelease Ign:1 file:/data/voxl-suite-offline-packages ./ InRelease Get:2 file:/data/voxl-suite-offline-packages ./ Release Ign:2 file:/data/voxl-suite-offline-packages ./ Release Get:3 file:/data/voxl-suite-offline-packages ./ Packages Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:3 file:/data/voxl-suite-offline-packages ./ Packages Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:3 file:/data/voxl-suite-offline-packages ./ Packages Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:3 file:/data/voxl-suite-offline-packages ./ Packages [8065 B] Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Get:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:4 file:/data/voxl-suite-offline-packages ./ Translation-en Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:3 file:/data/voxl-suite-offline-packages ./ Packages Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:3 file:/data/voxl-suite-offline-packages ./ Packages Ign:3 file:/data/voxl-suite-offline-packages ./ Packages Get:3 file:/data/voxl-suite-offline-packages ./ Packages Err:3 file:/data/voxl-suite-offline-packages ./ Packages File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory) Reading package lists... Done N: Download is performed unsandboxed as root as file '/data/voxl-suite-offline-packages/./InRelease' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied) E: Failed to fetch file:/data/voxl-suite-offline-packages/./Packages File not found - /data/voxl-suite-offline-packages/./Packages (2: No such file or directory) E: Some index files failed to download. They have been ignored, or old ones used instead. [INFO] Installing packages on target Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package voxl-suite [INFO] Pointing to correct repo /bin/bash: voxl-configure-pkg-manager: command not found [INFO] Done installing voxl-suite # anubhav @ anubhav-GF63-Thin-9SC in ~/Downloads/voxl2_platform_0.9.5/voxl-suite [22:46:34] $ adb shell root@m0054:/# root@m0054:/# -
@Anubhav Can you try with the command I posted above
flash-system-image.sh -f(note the "-f" flag, that's the important piece in this process)
