    VOXL heatsink
    VOXL
    • Nikhil RaneN
      Nikhil Rane
      Is there a recommended heatsink for the VOXL computer? We want to operate it in the temperature range -25 Celsius to 55 Celsius.
      Nikhil
      Nikhil RaneN 1 Reply Last reply Reply Quote 0
      • Nikhil RaneN
        Nikhil Rane @Nikhil Rane
        If yes, then can you recommend the part number, else, can you share the step/iges file of the board so we can design it ourselves.
        Nikhil
        • Chad SweetC
          Chad Sweet ModalAI Team
          We don't have a recommended heatsink. The two options we typically use:
          1. Use the airflow from the propellers. The drone's airflow is often enough to keep the Snapdragon running at full speed.
          2. Use the VOXL Cooling Fan. We have found this to have the best cooling/weight as compared to heatsinks
          In general, airflow works better than heatsinks. But, understandably some use cases won't allow for a fan. If that's the case it is desirable to capture some of the airflow from the propellers if possible.
          The 3D STEP file can be found at the datasheet
          Nikhil RaneN D 2 Replies Last reply Reply Quote 0
          • Nikhil RaneN
            Nikhil Rane @Chad Sweet
            @Chad-Sweet Thanks
            • D
              dddd @Chad Sweet
              @Chad-Sweet is there an update to the tested temperature range of the VOXL? The last post I saw from February said it was from 0-55C but did not have full environmental test info.
              • Chad SweetC
                We do have a customer who recently tested it was still operational at 85°C ambient
                Simon KristiansenS 1 Reply Last reply Reply Quote 0
                • Simon KristiansenS
                  Simon Kristiansen @Chad Sweet
                  @Chad-Sweet has anyone tested the negative temp rating. Hoping to see a -20 c.
