  3. Connecting FrSky x8r to the VOXL2 I/O
2 Posts 2 Posters 644 Views
  • Abdullah01A Offline
    Abdullah01A Offline
    Abdullah01
    I am using Voxl2 with I/O board to connect FrSky receiver.
    I am using FrSky x8R, and it has 3 pins (Voltage, Ground, and SBUS). Where on the other hand, the I/O does have SBUS Input/Output. I was trying to connect them to the SBUS on the receiver but it does not work.
    Should use only the one that is mentioned in the documentation the FrSky R-XSR?
    Thank you
    VinnyV 1 Reply Last reply
    • Abdullah01A Abdullah01
      Thank you
      VinnyV Offline
      VinnyV Offline
      Vinny
      Hi @Abdullah01
      I can try to help you with the hardware side.
      The FrSky RC receivers are a little confusing.
      They have several SBUS denoted ports on the module.
      This diagram shows which pins are utilized for our setup with the Voxl2 I/O board:
      https://docs.modalai.com/cable-datasheets/#mcbl-00065
      Apologies we do not have the MCBL-00065 for sale yet (it had an error we have yet to address), but if you are handy with a set of tweezers, and are willing to try these steps here to make your own, it's not that hard to pin the side needed for Voxl2 I/O with a 4-pin JST GH shroud.
      https://docs.modalai.com/cable-userguides/
      You can use a cable like this for starter material: https://docs.modalai.com/cable-datasheets/#mcbl-00015 and splice into the FrSky cable that came with your unit.
      Hope this helps!
