avahi not working
Hi, I've flashed
modalai-3-2-0-0.2.0.tar.gz(sys img and voxl suite) which has avahi 0.6.32root@HX88~ $ avahi-daemon --version avahi-daemon 0.6.32but can't ping my hostname.local:
root@HX88~ $ systemctl status avahi ● avahi-daemon.service - LSB: Avahi mDNS/DNS-SD Daemon Loaded: loaded (/etc/init.d/avahi-daemon) Active: inactive (dead) Docs: man:systemd-sysv-generator(8) root@HX88~ $ root@HX88~ $ systemctl start avahi root@HX88~ $ root@HX88~ $ systemctl status avahi -l ● avahi-daemon.service - LSB: Avahi mDNS/DNS-SD Daemon Loaded: loaded (/etc/init.d/avahi-daemon) Active: active (running) since Fri 2021-04-30 14:58:34 UTC; 2s ago Docs: man:systemd-sysv-generator(8) Process: 3496 ExecStart=/etc/init.d/avahi-daemon start (code=exited, status=0/SUCCESS) CGroup: /system.slice/avahi-daemon.service └─3501 avahi-daemon: running [HX88.local] Apr 30 14:58:34 HX88 systemd[1]: Starting LSB: Avahi mDNS/DNS-SD Daemon... Apr 30 14:58:34 HX88 avahi-daemon[3496]: * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon Apr 30 14:58:34 HX88 avahi-daemon[3501]: avahi-daemon 0.6.32 starting up. Apr 30 14:58:34 HX88 avahi-daemon[3501]: Loading service file /etc/avahi/services/multi.service. Apr 30 14:58:34 HX88 avahi-daemon[3501]: Network interface enumeration completed. Apr 30 14:58:34 HX88 avahi-daemon[3501]: Server startup complete. Host name is HX88.local. Local service cookie is 1523486884. Apr 30 14:58:34 HX88 systemd[1]: Started LSB: Avahi mDNS/DNS-SD Daemon. Apr 30 14:58:34 HX88 avahi-daemon[3501]: Service "9x25 MobileAP MDNS" (/etc/avahi/services/multi.service) successfully established. Apr 30 14:58:34 HX88 avahi-daemon[3496]: ...done. root@HX88~ $ root@HX88~ $ hostname HX88 root@HX88~ $ root@HX88~ $ ping HX88.local ping: unknown host HX88.localany hints?
Were you able to get this working? If not, we can take a look again.
this is still an issue after trying voxlplatform_3.3.0
however, uninstalling avahi (
opkg remove avahiand dependents) and install using https://gitlab.com/voxl-public/other/install-avahi works
