  3. PWM channel control for auxiliary functions
voxl-2-io
5 Posts 2 Posters 1.9k Views 1 Watching
  • Filip SlezakF Offline
    Filip Slezak
    Hi all,
    How should I go about controlling the PWM channel 7 or 8 (hexacopter airframe) from VOXL2 code and/or remote control? I can't find where the AUX channels are mapped
    Thx
    • wilkinsafW Offline
      wilkinsafW Offline
      wilkinsaf
        wilkinsafW Offline
        wilkinsaf
        This was completed with the VOXL Flight Core: https://www.youtube.com/watch?v=fxfyrUW3EyA
        Not sure if it helps on the VOXL2 IO
          Filip Slezak
          Yes, thanks. Although incomplete 🙂
          Need to configure quad_x_io.main.mix (find / -name "filename") with the code below where X is the channel defined in the 2nd link below (AUX1 5 or AUX2 6)
          # Hexacopter X airframe config
          R: 6x ...
          # For each AUX channel
          M: 1
          S: 3 X ...
          Writing this from home, sorry for '...' but simply copy the config to quad_x.main.mix to quad_x_io.main.mix, both these files are loaded on boot and if the io board is connected it overrides the former
          AUX1 will be on pin7 and AUX2 on pin8.
          1. https://docs.px4.io/v1.12/en/concept/mixing.html
          2. https://docs.modalai.com/voxl2-io-user-guide/#supported-mixers-and-airframe-setup
          Or properly rename the file and change the name being loaded in the px4 startup script but I didn't do that to avoid issues in case it's used by something else too...
            Filip Slezak
            Any tips on how to control this from ROS for offboard mode?
