    PWM channel control for auxiliary functions
    VOXL 2 IO
    • Filip SlezakF
      Filip Slezak
      Hi all,
      How should I go about controlling the PWM channel 7 or 8 (hexacopter airframe) from VOXL2 code and/or remote control? I can't find where the AUX channels are mapped
      Thx
      • wilkinsafW
        wilkinsaf ModalAI Team
        • wilkinsafW
          This was completed with the VOXL Flight Core: https://www.youtube.com/watch?v=fxfyrUW3EyA
          Not sure if it helps on the VOXL2 IO
          • Filip SlezakF
            Filip Slezak
            Yes, thanks. Although incomplete 🙂
            Need to configure quad_x_io.main.mix (find / -name "filename") with the code below where X is the channel defined in the 2nd link below (AUX1 5 or AUX2 6)
            # Hexacopter X airframe config
            R: 6x ...
            # For each AUX channel
            M: 1
            S: 3 X ...
            Writing this from home, sorry for '...' but simply copy the config to quad_x.main.mix to quad_x_io.main.mix, both these files are loaded on boot and if the io board is connected it overrides the former
            AUX1 will be on pin7 and AUX2 on pin8.
            1. https://docs.px4.io/v1.12/en/concept/mixing.html
            2. https://docs.modalai.com/voxl2-io-user-guide/#supported-mixers-and-airframe-setup
            Or properly rename the file and change the name being loaded in the px4 startup script but I didn't do that to avoid issues in case it's used by something else too...
            • Filip SlezakF
              Filip Slezak
              Any tips on how to control this from ROS for offboard mode?
