  3. Sentinel Drone - Voxel 2 Arived from factory Bricked
10 Posts 2 Posters 1.4k Views 2 Watching
  • J Offline
    jfunk
    After reading the quick star guides and getting my lunix machine set up with the android tools I powered up the drone for the first time and device is not available for adb shell or abd devices. I am using a USB A to C cable as suggested and I tried both ubuntu 22.04 and 18.04 with the same results. I can see the qualcomm device under lsusb.
    Also it appears my order was missing a cable. I got the sentinel drone with the 5g modem and the wifi adon but in the wifi kit there was no cable to plug the dongle to the drone, instead I was sent another voxl power module.
    • tomT Offline
      @jfunk What exactly do you see with lsusb on your host PC?
      • J Offline
        jfunk
        wrote on last edited by jfunk
        @tom
        for that USB device i see the following
        Bus 002 Device 010: ID 05c6:901d Qualcomm, Inc. KONA-QRD _SN:817893AD
        • tomT Offline
          wrote on last edited by tom
          @jfunk Great, that's the mode we expect it to be in so it's booting correctly. For example this is my machine:
          > lsusb | grep Qualcomm
          Bus 004 Device 033: ID 05c6:901d Qualcomm, Inc. KONA-QRD _SN:FDF5950D
          >  adb devices
          List of devices attached
          1639e2d2	device
          It seems as though something ADB just isn't recognizing the device correctly.
          The first thing to try would be:
          adb kill-server
          adb start-server
          adb devices
          You can also try running sudo adb devices and if it shows up then the udev rules will likely need to be modified, seen here: https://docs.modalai.com/voxl2-system-image/#missing-adb
          • J Offline
            jfunk
            @tom Ok i figured it out it was an additional problem that just found a solution for my machine. the android tools were installed in a wired state with how we have our mirror and proxys configured. that just got fixed and had to reinstall the android tools and is now behaving.
            Joe@555785-mitll:~$ adb devices
            e4aec865 device
            thank you.
            my second question about the usb cable to connect the wifi dongle was that supposed to come with the wifi kit?
            • tomT Offline
              @jfunk Is this the kit you bought? https://www.modalai.com/products/voxl-2-wifi-add-on-kit?_pos=1&_sid=4c5bc9495&_ss=r
              If so, is this the cable that is missing?: https://docs.modalai.com/cable-datasheets/#mcbl-00041
              It is supposed to include that cable so if it didn't come with your order I can get one sent to you.
              • tomT Offline
                @jfunk I found your order, it looks as though you purchased the WiFi add-on for sentinel, meaning the WiFi dongle would be installed on the Sentinel, is it missing from your drone?
                • J Offline
                  jfunk
                  @tom said in Sentinel Drone - Voxel 2 Arived from factory Bricked:
                  I was sent the alpha USB dongle and an extra Voxl Power module taped together. What is supposed to be installed on the drone for the wifi ad-on? from what i can tell from browsing the documentation it is the alpha dongle. but that was shipped still in its box in the case with the drone.
                  • tomT Offline
                    @jfunk I'm in discussion with our operations team regarding your order. Can you post a picture of what you received?
                    • J Offline
                      jfunk
                      @tom Unfortunately it will be a few days before i can get that to you, but what i can do is list off the items i received.
                      I received one sentinel drone with 5g modem and a set of propellers
                      one pelican case
                      4 batteries
                      2 wall power adapters
                      one alpha wireles dongle
                      one voxl power module as pictured
                      Note: the power module was taped to the alpha dongle (which was in the alpha box).
                      from looking through the documentation the usb break out for the wifi on the drone with a 5G modem is the 4 pin JST GH for usb2.0 on the modem carrier board itself. it it looks like all i was missing was the cable that plugs into that board and the wifi dongle. i saw a shipping notification so it appears something is on its way. Thank you
