  3. voxl-mavlink-server[3036]: ERROR message magic number wrong #284
Scheduled Pinned Locked Moved Flight Core and Legacy VOXL
ardupilot
9 Posts 3 Posters 5.8k Views 1 Watching
  • ModeratorM Offline
    wrote on last edited by Moderator
    @patrickpoirier Moving to a new topic from here for better visibility
    I have an other issue regarding connecting to ArduPilot
    It seems it is having issue with MavLink Message :
    And it seems to reconnect under a different ID
    Do you have a clue?
    Do you want me to open a new issue so we can follow more efficiently ?
    • Chad SweetC Online
      Chad SweetC Online
      An issue was recently identified where Mavlink 1 messages were causing issues. The fix is here on the stable branch. This might be related to what you are seeing
      • patrickpoirierP Offline
        patrickpoirier
        @Chad-Sweet thanks for the link, I will apply and report back
          patrickpoirier
          @Chad-Sweet still trying to figure out the best way to update the module.
          I would appreciate some guidance on the process, I mean do I have to build using voxl-emulator docker and upload the particular module ?
            patrickpoirier
            OK I have upodated to latest suite
            voxl-suite: 0.9.5
            Enabled services and configure
            voxl-configure-cameras 7 rotate_stereo
            voxl-configure-extrinsics seeker_v1_voxlcam
            Magig number error is gone, but still experience the mavlink crasg and reboot that makes multiple instances on Mavlink inspector as showned above
              patrickpoirier
              I decided to test on PX4
              Flashed the CUAV NORA with PX4 using QGgroundControl
              Connected and tested by looking at ODOMETRY signal
              Working Good
                patrickpoirier
                What would be the next step ?
                My use case requires ArduPilot and at the present stage it seems to be impractical unless you complete the complete integration.
                Meanwhile, I will try the ROS optin, but this is quite a big detour for something that I was expeting as "Plug and Play".
                  patrickpoirier
                  @Chad-Sweet
                  Could you implement a simple selection mode on the voxl-configure-vision-px4 allowing to specify px4 or ardupilot ?
                  And in the case of Ardupilot, just pass the qvio signal straight to mavlink (I guess it was like this before ?)
                    patrickpoirier
                    ok I found the problem...
                    the Cube Serial inteface are driven by TXS0108E Level Shifter powered both side with 3.3 volt making it marginal for the Voxl Primary Serial interface. Switching to secondary interface on the Voxl made it work correctly.
                    I sent a request for a change in the WIKI to reflect that configuration
