  3. gst-interpipe not getting installed
3 Posts 2 Posters 688 Views 1 Watching
  • Vaibhav UsapkarV Offline
    Vaibhav Usapkar
    wrote on last edited by Vaibhav Usapkar
    @Chad-Sweet , @modaltb , @Eric-Katzfey
    I am trying to install the gst-interpipe in voxl2, I am following the steps as mentioned on their page (https://developer.ridgerun.com/wiki/index.php/GstInterpipe_-_Building_and_Installation_Guide).
    However it doesn't get build correctly and hence unable to use the gst-interpipe.
    Attaching Log files and some snapshots for your reference.
    Appreciate any support on this.
    make Log
    make all-recursive
    make[1]: Entering directory '/etc/gst-interpipe'
    Making all in gst
    make[2]: Entering directory '/etc/gst-interpipe/gst'
    make -C interpipe
    make[3]: Entering directory '/etc/gst-interpipe/gst/interpipe'
    make[3]: Nothing to be done for 'all'.
    make[3]: Leaving directory '/etc/gst-interpipe/gst/interpipe'
    Making all in interpipe
    make[3]: Entering directory '/etc/gst-interpipe/gst'
    make[3]: Nothing to be done for 'all-am'.
    make[3]: Leaving directory '/etc/gst-interpipe/gst'
    make[2]: Leaving directory '/etc/gst-interpipe/gst'
    Making all in tests
    make[2]: Entering directory '/etc/gst-interpipe/tests'
    Making all in check
    make[3]: Entering directory '/etc/gst-interpipe/tests/check'
    make[3]: Leaving directory '/etc/gst-interpipe/tests/check'
    make[3]: Entering directory '/etc/gst-interpipe/tests'
    make[3]: Leaving directory '/etc/gst-interpipe/tests'
    make[2]: Leaving directory '/etc/gst-interpipe/tests'
    Making all in common
    make[2]: Entering directory '/etc/gst-interpipe/common'
    Making all in m4
    make[3]: Entering directory '/etc/gst-interpipe/common/m4'
    make[3]: Leaving directory '/etc/gst-interpipe/common/m4'
    make[3]: Entering directory '/etc/gst-interpipe/common'
    make[3]: Leaving directory '/etc/gst-interpipe/common'
    make[2]: Leaving directory '/etc/gst-interpipe/common'
    Making all in docs
    make[2]: Entering directory '/etc/gst-interpipe/docs'
    Making all in plugins
    make[3]: Entering directory '/etc/gst-interpipe/docs/plugins'
    make[3]: Leaving directory '/etc/gst-interpipe/docs/plugins'
    make[3]: Entering directory '/etc/gst-interpipe/docs'
    make[3]: Leaving directory '/etc/gst-interpipe/docs'
    make[2]: Leaving directory '/etc/gst-interpipe/docs'
    make[2]: Entering directory '/etc/gst-interpipe'
    make[2]: Leaving directory '/etc/gst-interpipe'
    make[1]: Leaving directory '/etc/gst-interpipe'
    sudo make install log
    Making install in gst
    make[1]: Entering directory '/etc/gst-interpipe/gst'
    Making install in interpipe
    make[2]: Entering directory '/etc/gst-interpipe/gst/interpipe'
    make[3]: Nothing to be done for 'install-exec-am'.
    /bin/mkdir -p '/usr/lib/x86_64-linux-gnu/gstreamer-1.0'
    /bin/sh ../../libtool --mode=install /usr/bin/install -c libgstinterpipe.la '/usr/lib/x86_64-linux-gnu/gstreamer-1.0'
    libtool: install: /usr/bin/install -c .libs/libgstinterpipe.so /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstinterpipe.so
    libtool: install: /usr/bin/install -c .libs/libgstinterpipe.lai /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstinterpipe.la
    libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin:/sbin" ldconfig -n /usr/lib/x86_64-linux-gnu/gstreamer-1.0
    Libraries have been installed in:
    If you ever happen to want to link against installed libraries
    in a given directory, LIBDIR, you must either use libtool, and
    specify the full pathname of the library, or use the '-LLIBDIR'
    flag during linking and do at least one of the following:
    • add LIBDIR to the 'LD_LIBRARY_PATH' environment variable
      during execution
    • add LIBDIR to the 'LD_RUN_PATH' environment variable
      during linking
    • use the '-Wl,-rpath -Wl,LIBDIR' linker flag
    • have your system administrator add LIBDIR to '/etc/ld.so.conf'
    See any operating system documentation about shared libraries for
    more information, such as the ld(1) and ld.so(8) manual pages.
    make[2]: Leaving directory '/etc/gst-interpipe/gst/interpipe'
    make[3]: Nothing to be done for 'install-data-am'.
    make[1]: Leaving directory '/etc/gst-interpipe/gst'
    Making install in tests
    make[1]: Entering directory '/etc/gst-interpipe/tests'
    Making install in check
    make[2]: Entering directory '/etc/gst-interpipe/tests/check'
    make[2]: Leaving directory '/etc/gst-interpipe/tests/check'
    make[1]: Leaving directory '/etc/gst-interpipe/tests'
    Making install in common
    make[1]: Entering directory '/etc/gst-interpipe/common'
    Making install in m4
    make[2]: Entering directory '/etc/gst-interpipe/common/m4'
    make[2]: Leaving directory '/etc/gst-interpipe/common/m4'
    make[1]: Leaving directory '/etc/gst-interpipe/common'
    Making install in docs
    make[1]: Entering directory '/etc/gst-interpipe/docs'
    Making install in plugins
    make[2]: Entering directory '/etc/gst-interpipe/docs/plugins'
    (installfiles=echo ./html/*.sgml ./html/*.html ./html/*.png ./html/*.css;
    if test "$installfiles" = './html/.sgml ./html/.html ./html/.png ./html/.css';
    then echo '-- Nothing to install' ;
    else
    /bin/sh /etc/gst-interpipe/install-sh -d /usr/local/share/gtk-doc/html/gst-interpipe-1.0;
    for i in $installfiles; do
    echo '-- Installing '$i ;
    /usr/bin/install -c -m 644 $i /usr/local/share/gtk-doc/html/gst-interpipe-1.0;
    done;
    pngfiles=echo ./html/*.png;
    if test "$pngfiles" != './html/.png'; then
    for i in $pngfiles; do
    done;
    fi;
    echo '-- Installing ./html/gst-interpipe-1.0.devhelp2' ;
    if test -e ./html/gst-interpipe-1.0.devhelp2; then
    /usr/bin/install -c -m 644 ./html/gst-interpipe-1.0.devhelp2
    /usr/local/share/gtk-doc/html/gst-interpipe-1.0/gst-interpipe-1.0.devhelp2;
    fi;
    /usr/bin/gtkdoc-rebase --relative --dest-dir= --html-dir=/usr/local/share/gtk-doc/html/gst-interpipe-1.0 || true ;
    fi)
    .sgml
    -- Installing ./html/GstInterPipeIListener.html
    -- Installing ./html/GstInterPipeINode.html
    -- Installing ./html/GstInterPipeSink.html
    -- Installing ./html/GstInterPipeSrc.html
    -- Installing ./html/api-index-full.html
    -- Installing ./html/ch01.html
    -- Installing ./html/ch02.html
    -- Installing ./html/deprecated-api-index.html
    -- Installing ./html/gst-interpipe-GstInterPipe.html
    -- Installing ./html/index.html
    -- Installing ./html/object-tree.html
    -- Installing ./html/home.png
    -- Installing ./html/left-insensitive.png
    -- Installing ./html/left.png
    -- Installing ./html/right-insensitive.png
    -- Installing ./html/right.png
    -- Installing ./html/up-insensitive.png
    -- Installing ./html/up.png
    -- Installing ./html/style.css
    make[2]: Leaving directory '/etc/gst-interpipe/docs/plugins'
    make[1]: Leaving directory '/etc/gst-interpipe/docs'
    make[2]: Nothing to be done for 'install-exec-am'.
    make[2]: Nothing to be done for 'install-data-am'.
    • Vaibhav UsapkarV Vaibhav Usapkar
      make Log
      make all-recursive
      Making all in gst
      make -C interpipe
      Making all in tests
      Making all in check
      Making all in m4
      Making all in docs
        during execution
        during linking
      else
      done;
      done;
      fi;
      fi;
      fi)
      .sgml
      @Vaibhav-Usapkar said in gst-interpipe not getting installed:
      x86_64-linux-gnu
      The only thing that jumps out at me is the x86_64-linux-gnu part. VOXL2 is aarch64, not x86, so maybe that is the issue?
        Vaibhav Usapkar
        Thanks for the response.
        It worked !!
