  3. Connecting voxl2io UART port to voxl ESC V2?
4 Posts 3 Posters 577 Views 1 Watching
    I am using system image 1.4.1 on voxl2. I want to operate VOXL ESC V2 on px4io UART port on J19 instead of J18. Is it possible? I tried to change port name on modalai_esc mixer load command to /dev/px4io, also routed TX,RX and GND pins to J19 pins 12,11 and 10, but it didnt worked. Please help me to get clearity if it is possible since both UART both seems to be going to SLPI processor.
    Thank you in advance!
      @Chad-Sweet Please respond back on this. I want to connect ModalAI ESC V2 to J19 instead of J18 since my J18 port got damaged and is beyond recovery but still I want to utilize VOXL2 + ModalAI ESC for further operations. Is it possible to use J19 VOXL2IO UART QUP7 for Modalai ESC V2?
      VinnyV 1 Reply Last reply
      • ? A Former User
        VinnyV Offline
        VinnyV Offline
        Vinny
        Hi @Aks
        I cannot speak for the SW team, but I am curious how damaged your J18 port is, and if you are willing to share a photo of it, I might be able to help confirm or offer tips/insight for repairs.
          Hi @Aks ,
          Out of the box no, but if you are recompiling SW yourself than it's likely doable, but we have not tested this.
          voxl-px4 utilizes the DSP for it's IO on VOXL2, do the UARTs aren't exposed to Ubuntu like a normal UART (/dev/ttyHX). Instead it's a little deep in voxl-px4 at this time.
          The current production release is a 1.12 based branch, called voxl-dev-1.12.
          For example, the QUP2 port is defined here for the ESC:
          https://github.com/modalai/px4-firmware/blob/voxl-dev-1.12/src/drivers/uart_esc/modalai_esc/modalai_esc.cpp#L42
          And QUP7 is defined to be used by px4io here:
          https://github.com/modalai/px4-firmware/blob/voxl-dev-1.12/platforms/qurt/src/px4/generic/generic/px4io_serial/px4io_serial.cpp#L67
          For reference, I used my own graphic to remember the QUP indicies, here:
          https://docs.modalai.com/voxl-px4-developer-guide/
          specifically:
          https://docs.modalai.com/images/voxl2/m0054-px4-block-diagram-0.4.png
          Although we haven't tried this, you may be able to recompile with updates here to the QUP index and get things going that way.
