  2. FAQs
  3. My VOXL has benn brick.
Scheduled Pinned Locked Moved Unsolved FAQs
4 Posts 2 Posters 1.6k Views 2 Watching
  • S Offline
    S Offline
    shlee853
    Hi guys,
    My VOXL has been brick.
    But I don't have debug module.
    Is there any method to unbrick without debug module?
    especially, I have PDDL module and checked it has emergency switch to enter factory mode.
    Can I recover my VOXL in emergency mode?
      Hi @shlee853 ,
      Unfortunately that switch on the Microhard modem is a lower level factory emergency boot switch only. It can be used in conjunction with a factory level "QFIL" application that we can't distribute. When enabled, the device boots up into a special mode, but fastboot can't see it in this mode.
      What will likely be needed is the Debug module with the "fastboot" switch.
      Question: have you attempted to boot up with/without the Modem attached? Trying to eliminate possible issues.
        Also, if cameras get plugged in backwards (I've done this myself too many times....) then the VOXL might not boot up.
        S 1 Reply Last reply
        • modaltbM modaltb
          S Offline
          S Offline
          shlee853
          @modaltb thanks for your reply.
          I have a VOXL flight deck and I didn’t change camera installation on it.
          When I stopped updating system software then my VOXL has been brick.
          Ok I’ll prepare debug board to treat fast boot.
          Thanks buddy
