    My VOXL has benn brick.
    FAQs
    • S
      shlee853
      Hi guys,
      My VOXL has been brick.
      But I don't have debug module.
      Is there any method to unbrick without debug module?
      especially, I have PDDL module and checked it has emergency switch to enter factory mode.
      Can I recover my VOXL in emergency mode?
      • modaltbM
        modaltb ModalAI Team
        Hi @shlee853 ,
        Unfortunately that switch on the Microhard modem is a lower level factory emergency boot switch only. It can be used in conjunction with a factory level "QFIL" application that we can't distribute. When enabled, the device boots up into a special mode, but fastboot can't see it in this mode.
        What will likely be needed is the Debug module with the "fastboot" switch.
        Question: have you attempted to boot up with/without the Modem attached? Trying to eliminate possible issues.
        • modaltbM
          Also, if cameras get plugged in backwards (I've done this myself too many times....) then the VOXL might not boot up.
          • S
            shlee853 @modaltb
            @modaltb thanks for your reply.
            I have a VOXL flight deck and I didn’t change camera installation on it.
            When I stopped updating system software then my VOXL has been brick.
            Ok I’ll prepare debug board to treat fast boot.
            Thanks buddy
