  3. Could MicroSD card support in VOXL2 system image?
5 Posts 3 Posters 1.0k Views 1 Watching
  • D Offline
    D Offline
    DanChang
    Hi ModalAI team,
    We plan to support MicroSD card with add-on hardware and store the image data and logging data in MicroSD card with default configuration on VOXL2.
    1. Does VOXL2 system image support this feature current?
    2. If no, should we enable it by ourselves and how?
      Best Regards,
      Dan
      Yes, it is enabled
      D 1 Reply Last reply
      • Chad SweetC Chad Sweet
        Yes, it is enabled
        D Offline
        D Offline
        DanChang
        @Chad-Sweet Thanks and whether or not the default configuration of image and logging data is set to MicroSD card?
        Dan
        VinnyV 1 Reply Last reply
        • D DanChang
          Dan
          VinnyV Offline
          VinnyV Offline
          Vinny
          Hi @DanChang ,
          I'm chiming in just from the HW side... I know you still have an open SW question.
          Be sure to give us an opportunity to review your plug-in board Schematic. We will do it as a courtesy. We want to make sure you get things right the first time.
          SD card is straightforward, but also easy to get wrong.
          Have you seen this starter board to help you along your way?
          https://docs.modalai.com/voxl2-connectors/#add-on-board-to-board-design-package
          We have an internal dev debug board that we do not sell normally that might help (it has an SD and UFS card combo socket), but you'd have to email us in the contact form to ask if it is available to buy and at what price.
          • VinnyV Vinny
            Hi @DanChang ,
            D Offline
            D Offline
            DanChang
            @Vinny Thanks for your comments. Actually we have sent the block diagram to Chad for review. Once we have done the schematic, we will send to ModalAI for review.
            • S sja123 referenced this topic on
