    ToF sensor and VOA
    1445
    • X
      xav04
      Hi, I'd like to know if is it possible to use a ToF sensor for obstacle avoidance with voxl2. To give you more context, when I run voxl-inspect-tof I get the correct distance measurements. I modified /etc/modalai/voxl-vision-px4.conf , where "en_voa" is set to true and "voa_inouts" only accepts "tof".
      To verify that this is working I run voxl-vision-px4 -s but all distances are none. Please let me know how I can fix this.
      Also, is it possible to see objects with a shorter range using ToF, like around 1m?
        Yes this should absolutely be possible, can you send the screenshot of your voxl-vision config file as well.
        As for range we usually cut off the tof data around 15 cm in front of the camera, so it usually has an effective range of ~0.15-5 meters
        X 2 Replies Last reply Reply Quote 0
        • X
          xav04
          Hi @Alex-Gardner, sure! This is the configuration of /etc/modalai/voxl-vision-px4.conf.
          If there is any other parameter that can be improved please let me know
          • X
            xav04 @Guest
            Hi @Alex-Gardner , is there any other file I should upload?
            • X
              xav04 @Guest
              @Alex-Gardner I'm wondering if you can help me solve this problem or is there someone else on the development team who can provide support?
                Can you check in voxl-portal what the pointcloud voxl_pc_out looks like? this is the VOA pointcloud before the final bit of filtering to send it to the flight controller.
                Also check /etc/modalai/extrinsics.conf to make sure that it matches the transforms that are on your drone.
                X 1 Reply Last reply Reply Quote 0
                • X
                  xav04 @Guest
                  Hi @Alex-Gardner this is the screenshot of voxl_pc_out in voxl-portal, at the same time this is the output of voxl-vision-px4 -s and this is the screenshot /etc/modalai/extrinsics.conf
                  • James StrawsonJ
                    James Strawson ModalAI Team
                    your image of the voa_pc_out point cloud shows that your voxl thinks the TOF is pointing out the top of the drone. This is confirmed by your extrinsics conf sensor rotation: [180 0 0] which translates to a sensor pointing straight up.
                    • S
                      Sarika Sharma @James Strawson
                      @James-Strawson Hii , I am also getting the same issue . Kindly look at the following details . I have defined tof in my extrinsics.conf file as given below:
                      parent: body
                      child: tof
                      T_child_wrt_parent: 0.070 0.024 -0.029
                      RPY_parent_to_child: 0.0 90.0 90.0
                      R_child_to_parent: 0.000 -0.000 1.000
                      1.000 0.000 -0.000
                      -0.000 1.000 0.000
                      when i run voxl-vision-hub -s i got the following
                      slice 0 dist none back
                      slice 1 dist none
                      slice 2 dist none
                      slice 3 dist none
                      slice 4 dist none
                      slice 5 dist none
                      slice 6 dist none
                      slice 7 dist none
                      slice 8 dist none
                      slice 9 dist none left
                      slice 10 dist none
                      slice 11 dist none
                      slice 12 dist none
                      slice 13 dist none
                      slice 14 dist none
                      slice 15 dist none
                      slice 16 dist none
                      slice 17 dist none
                      slice 18 dist none forward
                      slice 19 dist none
                      slice 20 dist none
                      slice 21 dist none
                      slice 22 dist none
                      slice 23 dist none
                      slice 24 dist none
                      slice 25 dist none
                      slice 26 dist none
                      slice 27 dist none right
                      slice 28 dist none
                      and in my vision-hub-conf file i have the folloeing set up:
                      "en_vio": true,
                      "vio_pipe": "qvio",
                      "secondary_vio_pipe": "ov",
                      "vfc_vio_pipe": "ov",
                      "vio_warmup_s": 3,
                      "send_odom_while_failed": true,
                      "horizon_cal_tolerance": 0.5,
                      "en_hitl": false,
                      "offboard_mode": "figure_eight",
                      "follow_tag_id": 0,
                      "figure_eight_move_home": true,
                      "collision_sampling_dt": 0.1,
                      "max_lookahead_distance": 1,
                      "backtrack_seconds": 60,
                      "backtrack_rc_chan": 8,
                      "backtrack_rc_thresh": 1500,
                      "wps_move_home": true,
                      "wps_stride": 0,
                      "wps_timeout": 0,
                      "wps_damp": 1,
                      "wps_vfc_mission": true,
                      "wps_vfc_mission_loop": false,
                      "wps_vfc_mission_to_ramp": 25,
                      "wps_vfc_mission_to_kp": 0.10000000149011612,
                      "wps_vfc_mission_cruise_speed": 1,
                      "en_tag_fixed_frame": false,
                      "fixed_frame_filter_len": 5,
                      "en_transform_mavlink_pos_setpoints_from_fixed_frame": false,
                      "vfc_rate": 100,
                      "vfc_rc_chan_min": 980,
                      "vfc_rc_chan_max": 2020,
                      "vfc_thrust_ch": 3,
                      "vfc_roll_ch": 1,
                      "vfc_pitch_ch": 2,
                      "vfc_yaw_ch": 4,
                      "vfc_submode_ch": 6,
                      "vfc_alt_mode_rc_min": 0,
                      "vfc_alt_mode_rc_max": 0,
                      "vfc_flow_mode_rc_min": 0,
                      "vfc_flow_mode_rc_max": 0,
                      "vfc_hybrid_flow_mode_rc_min": 0,
                      "vfc_hybrid_flow_mode_rc_max": 0,
                      "vfc_position_mode_rc_min": 0,
                      "vfc_position_mode_rc_max": 2100,
                      "vfc_traj_mode_rc_min": 0,
                      "vfc_traj_mode_rc_max": 0,
                      "vfc_yaw_deadband": 30,
                      "vfc_vxy_deadband": 50,
                      "vfc_vz_deadband": 150,
                      "vfc_min_thrust": 0,
                      "vfc_max_thrust": 0.800000011920929,
                      "vfc_tilt_max": 0.43599998950958252,
                      "vfc_yaw_rate_max": 3,
                      "vfc_thrust_hover": 0.5,
                      "vfc_vz_max": 1,
                      "vfc_kp_z": 5.2899999618530273,
                      "vfc_kd_z": 5.9800000190734863,
                      "vfc_vxy_max": 3,
                      "vfc_kp_xy": 0.63999998569488525,
                      "vfc_kd_xy": 2.559999942779541,
                      "vfc_kp_z_vio": 5.2899999618530273,
                      "vfc_kd_z_vio": 5.9800000190734863,
                      "vfc_kp_xy_vio": 3.2400000095367432,
                      "vfc_kd_xy_vio": 3.9600000381469727,
                      "vfc_w_filt_xy_vio": 10,
                      "vfc_w_filt_xy_flow": 3,
                      "vfc_vel_ff_factor_vio": 0.899999976158142,
                      "vfc_xy_acc_limit_vio": 2.5,
                      "vfc_max_z_delta": 3,
                      "vfc_att_transition_time": 0.5,
                      "vfc_stick_move_threshold": 30,
                      "vfc_flow_transition_time": 1,
                      "vfc_q_min": 10,
                      "vfc_points_min": 7,
                      "vfc_en_submode_announcement": 1,
                      "vfc_disable_fallback": false,
                      "vfc_traj_csv": "/data/voxl-vision-hub/traj.csv",
                      "en_voa": true,
                      "voa_upper_bound_m": -0.15000000596046448,
                      "voa_lower_bound_m": 0.15000000596046448,
                      "voa_memory_s": 1,
                      "voa_max_pc_per_fusion": 100,
                      "voa_pie_max_dist_m": 20,
                      "voa_pie_min_dist_m": 0.25,
                      "voa_pie_under_trim_m": 1,
                      "voa_pie_threshold": 3,
                      "voa_send_rate_hz": 20,
                      "voa_pie_slices": 36,
                      "voa_pie_bin_depth_m": 0.15000000596046448,
                      "voa_inputs": [{
                      "enabled": false,
                      "type": "point_cloud",
                      "input_pipe": "dfs_point_cloud",
                      "frame": "stereo_l",
                      "max_depth": 8,
                      "min_depth": 0.300000011920929,
                      "cell_size": 0.079999998211860657,
                      "threshold": 4,
                      "x_fov_deg": 68,
                      "y_fov_deg": 56,
                      "conf_cutoff": 0
                      "enabled": false,
                      "input_pipe": "stereo_front_pc",
                      "frame": "stereo_front_l",
                      "max_depth": 8,
                      "threshold": 4,
                      "x_fov_deg": 68,
                      "y_fov_deg": 56,
                      "conf_cutoff": 0
                      "enabled": false,
                      "input_pipe": "stereo_rear_pc",
                      "frame": "stereo_rear_l",
                      "max_depth": 8,
                      "threshold": 4,
                      "x_fov_deg": 68,
                      "y_fov_deg": 56,
                      "conf_cutoff": 0
                      "enabled": true,
                      "type": "tof",
                      "input_pipe": "tof",
                      "frame": "tof",
                      "max_depth": 6,
                      "min_depth": 0.15000000596046448,
                      "threshold": 3,
                      "x_fov_deg": 106.5,
                      "y_fov_deg": 85.0999984741211,
                      "conf_cutoff": 125
                      "enabled": false,
                      "type": "rangefinder",
                      "input_pipe": "rangefinders",
                      "frame": "body",
                      "max_depth": 8,
                      "threshold": 4,
                      "x_fov_deg": 68,
                      "y_fov_deg": 56,
                      "conf_cutoff": 0
                      "voa_voa_memory_s": 1
