Which Hires to use?
I use Voxl deck indoor and one of the function I look for is to take photos from 1 to 1,5m distance from the objects, and still be able to see details as small numbers or letters in these photos.
I tried with the mounted hires cam on Voxl (IMX 214) but the maximum distance I got to work is about 0,5m from the target event on trying to adjust the focus on it.
Can you let me know how to proceed? do I need to change the hires cam? if yes, please recommend which hires cam can work for my case.
I would like to specify, that I was looking to use a hires cam featured by Modalai. The only one I found in your catalogue is MSU-M0026-1-01.
Did this camera can be good for my case? Did this camera can be used with other lens if needed?
@ModalaiTeam your support on this will be much appreciated. Thanks!
@Chad-Sweet Thanks Chad! Do you have a date when the M0061 could be available?
We are hoping for mid-December as a core component is on order
@Chad-Sweet Thanks for your support!
