    Which Hires to use?
    Image Sensors
    • M
      marian
      I use Voxl deck indoor and one of the function I look for is to take photos from 1 to 1,5m distance from the objects, and still be able to see details as small numbers or letters in these photos.
      I tried with the mounted hires cam on Voxl (IMX 214) but the maximum distance I got to work is about 0,5m from the target event on trying to adjust the focus on it.
      Can you let me know how to proceed? do I need to change the hires cam? if yes, please recommend which hires cam can work for my case.
      • M
        marian @marian
        I would like to specify, that I was looking to use a hires cam featured by Modalai. The only one I found in your catalogue is MSU-M0026-1-01.
        Did this camera can be good for my case? Did this camera can be used with other lens if needed?
        • M
          marian
          @ModalaiTeam your support on this will be much appreciated. Thanks!
          • Chad SweetC
            Chad Sweet ModalAI Team
            I don't think there is any way for us to answer that question for you. Both the M0026 and M0061 modules have m12 lenses which would allow you to select on your own.
            • M
              marian
              @Chad-Sweet Thanks Chad! Do you have a date when the M0061 could be available?
              • Chad SweetC
                We are hoping for mid-December as a core component is on order
                • M
                  marian
                  @Chad-Sweet Thanks for your support!
