  3. Error: gst_rtsp_server_attach_failed
7 Posts 2 Posters 972 Views 1 Watching
  • M Offline
    M Offline
    Moodsh00
    Trying to get rtsp stream from hi res camera of sentinel voxl2. I dont have doodle labs or 5g. Can someone please help as im getting above error. Camera server connected. The pc is connected direct to voxl wifi. In rtsp-streamer it seems to get 0 from gst rtsp server attach after creating rtsp server main loop source for callback. Cannot find any info online to get past this.
      Hi @Moodsh00 ,
      Have you tried using voxl-streamer ? This would be the preferred way of using gst
      https://docs.modalai.com/voxl-streamer/
      Source code here:
      https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-streamer
      M 1 Reply Last reply
      • M Offline
        M Offline
        Moodsh00
        Thanks for reply. The error message referred to is actually from voxl-streamer. I enter the shell; then type voxl-streamer. It responds saying:
        using config file etc/modalai/voxl-streamer
        ERROR: gst rtsp server attach fail
        • modaltbM modaltb
          Hi @Moodsh00 ,
          Source code here:
          M Offline
          M Offline
          Moodsh00
          @modaltb
            If you run voxl-inspect-cam -a do you have hires showing up?
            Can check out this config file: /etc/modalai/voxl-streamer.conf
            Here's hires example config: https://docs.modalai.com/voxl-streamer/#high-resolution-hires-camera-example
            M 2 Replies Last reply
            • modaltbM modaltb
              M Offline
              M Offline
              Moodsh00
              @modaltb
              Yes it shows up. 480X640 with 11.90ms exposure and gt =2
              It also shows up fine in the web portal
              • modaltbM modaltb
                M Offline
                M Offline
                Moodsh00
                @modaltb
                I figured it out this weekend. It had to do with a swap file in streamer config. I deleted the file and rtsp showed up. However now im trying to get rtsp stream quality to match the quality on voxl portal. Its really grainy. I tried the config files in streamer at 1920X1080 and increased the bitrate by a factor of 5. Will try the camera server today.
                Also; is there a way to stream to both vlc and gcs at same time. The feed cuts when i try a second viewer.
                Lastly; is there a way to keep the rtsp stream connected to gcs from bootup. It seems like when i close the shell; the rtsp stream to gcs gets lost.
                Many thanks again.
