    VOXL UVC Server not connecting
    2281
    • KrisK
      Kris
      I have been trying to connect my UVC camera to view either in VLC or in QGC.
      I thought if I followed the guide for the VOXL UVC Server, that it would work or at least get me in the right direction.
      When I enter;
      voxl:~$ voxl-uvc-server
      nothing happens.
      voxl:~$ voxl-version
      system-image: 3.8.0
      kernel:       #1 SMP PREEMPT Tue Apr 26 18:08:39 UTC 2022 3.18.71-perf
      hw version:   VOXL
      voxl-suite:   0.8.1
      0.7.0
      voxl:~$ voxl-inspect-services
       docker-daemon            | Disabled  | Not Running |
       voxl-camera-server       |  Enabled  |   Running   |    18.0
       voxl-cpu-monitor         |  Enabled  |   Running   |     0.0
       voxl-dfs-server          |  Enabled  | Not Running |
       voxl-imu-server          |  Enabled  |   Running   |     2.0
       voxl-mavlink-server      |  Enabled  |   Running   |     2.0
       voxl-portal              |  Enabled  |   Running   |     0.0
       voxl-qvio-server         |  Enabled  |   Running   |     8.0
       voxl-streamer            | Disabled  | Not Running |
       voxl-tag-detector        |  Enabled  | Not Running |
       voxl-vision-px4          |  Enabled  |   Running   |     2.0
      voxl:~$ cd /home/root/ipk
      voxl:~/ipk$ opkg update
      Downloading http://voxl-packages.modalai.com/dists/apq8096/stable/binary-arm64//Packages.gz.
      Updated source 'modalai'.
      voxl:~/ipk$ opkg install voxl-uvc-server
      Package voxl-uvc-server (0.1.1) installed in root is up to date.
      voxl:~/ipk$ cd
      ^Cvoxl:~$
      voxl:~$ voxl-uvc-server -m
      Enabling MPA debug messages
      ^Chelper thread received sigusr 10
      channel 0 request thread closing
      voxl:~$
      voxl:~$ voxl-uvc-server -d
      Enabling debug messages
      voxl-uvc-server starting
      Image resolution 640x480, 30 fps chosen
      UVC initialized
      Device found
      Device opened
      uvc_get_stream_ctrl_format_size succeeded for format 0
      Streaming starting
      Got frame callback! frame_format = 3, width = 640, height = 480, length = 614400, ptr = (nil)
       * got image 30
       * got image 60
       * got image 90
       * got image 120
       * got image 150
       * got image 180
       * got image 210
       * got image 240
       * got image 270
      ^CGot SIGINT, exiting
      Done streaming
      UVC exited
      voxl-uvc-server ending
      voxl:~$
      • Eric KatzfeyE
        Eric Katzfey ModalAI Team @Kris
        @Kris What do you get if you try voxl-uvc-server -s?
        KrisK 1 Reply Last reply Reply Quote 0
        • KrisK
          Kris @Eric Katzfey
          Hi, @Eric-Katzfey.
          This is what I get.
          voxl:~$ voxl-uvc-server -s
          *** START DEVICE LIST ***
          Found device 1
          Got device descriptor for 0bda:3035 200901010001
          Found device 0bda:3035
          DEVICE CONFIGURATION (0bda:3035/200901010001) ---
          Status: idle
          VideoControl:
          	bcdUVC: 0x0100
          VideoStreaming(1):
          	bEndpointAddress: 129
          	Formats:
          	MJPEGFormat(1)
          		  bits per pixel: 0
          		  GUID: 4d4a5047000000000000000000000000 (MJPG)
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  bit rate: 995328000-995328000
          			  max frame size: 4147200
          			  default interval: 1/30
          			  interval[0]: 1/30
          			FrameDescriptor(2)
          			  capabilities: 00
          			  bit rate: 147456000-147456000
          			  max frame size: 614400
          			  interval[0]: 1/30
          			FrameDescriptor(3)
          			  capabilities: 00
          			  bit rate: 230400000-230400000
          			  max frame size: 960000
          			  interval[0]: 1/30
          			FrameDescriptor(4)
          			  capabilities: 00
          			  bit rate: 377487360-377487360
          			  max frame size: 1572864
          			  interval[0]: 1/30
          			FrameDescriptor(5)
          			  capabilities: 00
          			  bit rate: 442368000-442368000
          			  max frame size: 1843200
          			  interval[0]: 1/30
          			FrameDescriptor(6)
          			  capabilities: 00
          			  bit rate: 589824000-589824000
          			  max frame size: 2457600
          			  interval[0]: 1/30
          			FrameDescriptor(7)
          			  capabilities: 00
          			  bit rate: 986112000-986112000
          			  max frame size: 4108800
          			  interval[0]: 1/30
          			FrameDescriptor(8)
          			  capabilities: 00
          			  bit rate: 1509949440-1509949440
          			  max frame size: 6291456
          			  interval[0]: 1/30
          			FrameDescriptor(9)
          			  capabilities: 00
          			  bit rate: -1876320256--1876320256
          			  max frame size: 10077696
          			  interval[0]: 1/30
          			FrameDescriptor(10)
          			  capabilities: 00
          			  interval[0]: 1/30
          			StillFrameDescriptor
          			  bEndPointAddress: 00
          			  wWidth(1) = 1920
          			  wHeight(1) = 1080
          			  wWidth(2) = 640
          			  wHeight(2) = 480
          			  wWidth(3) = 640
          			  wHeight(3) = 480
          			  wWidth(4) = 640
          			  wHeight(4) = 480
          			  wWidth(5) = 640
          			  wHeight(5) = 480
          			  wWidth(6) = 640
          			  wHeight(6) = 480
          			  wWidth(7) = 640
          			  wHeight(7) = 480
          			  wWidth(8) = 640
          			  wHeight(8) = 480
          			  wWidth(9) = 640
          			  wHeight(9) = 480
          	UncompressedFormat(2)
          		  bits per pixel: 16
          		  GUID: 5955593200001000800000aa00389b71 (YUY2)
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  bit rate: 99532800-99532800
          			  interval[0]: 1/3
          			FrameDescriptor(2)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(3)
          			  capabilities: 00
          			  bit rate: 117964800-117964800
          			  default interval: 1/8
          			  interval[0]: 1/8
          			FrameDescriptor(4)
          			  capabilities: 00
          			  bit rate: 153600000-153600000
          			  default interval: 1/20
          			  interval[0]: 1/20
          			FrameDescriptor(5)
          			  capabilities: 00
          			  bit rate: 157286400-157286400
          			  interval[0]: 1/8
          			FrameDescriptor(6)
          			  capabilities: 00
          			  bit rate: 150994944-150994944
          			  interval[0]: 1/3
          			FrameDescriptor(7)
          			  capabilities: 00
          			  bit rate: 161243136-161243136
          voxl:~$ lsusb
          Bus 001 Device 003: ID 0bda:3035 Realtek Semiconductor Corp.
          Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
          Found device 1
          Status: idle
          VideoControl:
          	bcdUVC: 0x0100
          VideoStreaming(1):
          	Formats:
          	MJPEGFormat(1)
          		  bits per pixel: 0
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(2)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(3)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(4)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(5)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(6)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(7)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(8)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(9)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(10)
          			  capabilities: 00
          			  interval[0]: 1/30
          			  wWidth(1) = 1920
          			  wHeight(1) = 1080
          			  wWidth(2) = 640
          			  wHeight(2) = 480
          			  wWidth(3) = 640
          			  wHeight(3) = 480
          			  wWidth(4) = 640
          			  wHeight(4) = 480
          			  wWidth(5) = 640
          			  wHeight(5) = 480
          			  wWidth(6) = 640
          			  wHeight(6) = 480
          			  wWidth(7) = 640
          			  wHeight(7) = 480
          			  wWidth(8) = 640
          			  wHeight(8) = 480
          			  wWidth(9) = 640
          			  wHeight(9) = 480
          		  bits per pixel: 16
          		  default frame: 1
          		  aspect ratio: 0x0
          		  interlace flags: 00
          		  copy protect: 00
          			FrameDescriptor(1)
          			  capabilities: 00
          			  interval[0]: 1/3
          			FrameDescriptor(2)
          			  capabilities: 00
          			  interval[0]: 1/30
          			FrameDescriptor(3)
          			  capabilities: 00
          			  interval[0]: 1/8
          			FrameDescriptor(4)
          			  capabilities: 00
          			  interval[0]: 1/20
          			FrameDescriptor(5)
          			  capabilities: 00
          			  interval[0]: 1/8
          			FrameDescriptor(6)
          			  capabilities: 00
          			  interval[0]: 1/3
          			FrameDescriptor(7)
          			  capabilities: 00
          			  interval[0]: 1/2
          			FrameDescriptor(8)
          			  capabilities: 00
          			  interval[0]: 1/3
          			  wWidth(1) = 640
          			  wHeight(1) = 480
          			  wWidth(2) = 1920
          			  wHeight(2) = 1080
          			  wWidth(3) = 1280
          			  wHeight(3) = 720
          			  wWidth(4) = 2592
          			  wHeight(4) = 1944
          END DEVICE CONFIGURATION
          *** END DEVICE LIST ***
          voxl:~$
          voxl:~$ lsusb
          • Eric KatzfeyE
            @Kris Okay, that all looks good. What about voxl-uvc-server -d -m?
            • KrisK
              Kris @Eric Katzfey
              @Eric-Katzfey
              voxl:~$ voxl-uvc-server -d -m
              UVC initialized
              Device found
              Device opened
              Streaming starting
               * got image 30
               * got image 60
               * got image 90
               * got image 120
               * got image 150
               * got image 180
               * got image 210
               * got image 240
               * got image 270
               * got image 300
               * got image 330
               * got image 360
               * got image 390
               * got image 420
               * got image 450
               * got image 480
               * got image 510
               * got image 540
               * got image 570
               * got image 600
               * got image 630
               * got image 660
               * got image 690
               * got image 720
               * got image 750
               * got image 780
               * got image 810
               * got image 840
               * got image 870
               * got image 900
               * got image 930
               * got image 960
               * got image 990
              Done streaming
              UVC exited
              voxl:~$
              • Eric KatzfeyE
                @Kris Okay, so that shows that voxl-uvc-server is running.
                • KrisK
                  Kris @Eric Katzfey
                  @Eric-Katzfey
                  What do I need to do to view the images/video from my UVC camera?
                  voxl:~$ show-video-device-info.sh
                  /dev/video2: USB Camera 0bda:3035
                  • Eric KatzfeyE
                    @Kris You run voxl-uvc-server to get the frames from the camera. See docs.modalai.com/voxl-uvc-server for more information. Then you run voxl-streamer -c uvc-generic to create an RTSP stream that can be viewed remotely using VLC or QGC. Se docs.modalai.com/voxl-streamer for more information.
                    KrisK 2 Replies Last reply Reply Quote 0
                    • KrisK
                      Kris @Eric Katzfey
                      @Eric-Katzfey
                      This is where I am a little confused. Do I need to SSH into VOXL and run the
                      in one terminal. Then open a new terminal, SSH into VOXL again and run
                      voxl:~$ voxl-streamer -c uvc-generic
                      • KrisK
                        Kris @Eric Katzfey
                        @Eric-Katzfey Ok, Thank you!!! I finally got it working 👍
                        • Eric KatzfeyE
                          @Kris I usually use adb shell to setup two separate sessions. I run voxl-uvc-server in one and voxl-streamer in the other.
                          • KrisK
                            Kris @Eric Katzfey
                            @Eric-Katzfey How can I change the frame rates, etc.
                            Or edit the config files?
                            • KrisK
                              Kris @Eric Katzfey
                              @Eric-Katzfey I am trying to get better quality because I need to record via some type of Screen Recorder. I would prefer to save the recorded videos to an SD card, but I don't think that is possible.
                              • Eric KatzfeyE
                                @Kris Yes, you can edit the config files to change resolution, frame rate, etc.
                                • Eric KatzfeyE
                                  @Kris We don't currently have a way to save to SD card from the UVC camera. However, you can create your own code to do this. This is a feature that we will be adding in the future.
                                  • KrisK
                                    Kris @Eric Katzfey
                                    @Eric-Katzfey Would I edit the config files from the "uvc-geneirc" at the top or the "uvc-video" at the bottom of the config files?
                                    • Eric KatzfeyE
                                      @Kris If you are using the uvc-generic configuration then that is the one that you would edit.
                                      • KrisK
                                        Kris @Eric Katzfey
                                        @Eric-Katzfey Got it 👍
                                        Thank you for your help and quick responses 😊
                                        • local adL
                                          local ad
                                          WOW what a great thread, so on time for me Thanks Kris
