    Example to stream video via ffmpeg
    Software Development
    1731
    • Ruijie GengR
      Ruijie Geng
      In this documentation(https://docs.modalai.com/docker-on-voxl/#access-to-mipi-cameras), last part, I get this code
      ffmpeg -an -sn -f rawvideo -pix_fmt nv21 -s:v 640x480 -i /opt/frame0 <output options>
      I already set up the docker with roskinetic-xenial_v1_0. Would you like to give an example to use FFmpeg? I want to stream the visual data and view such data on my laptop.
      I tried to save the video locally. but the system give me error
      ffmpeg -an -sn -f rawvideo -pix_fmt nv21 -s:v 640x480 -i /opt/frame0 output.mov
      /opt/frame0: Is a directory
      Thank you!
      • tomT
        tom admin
        @Ruijie-Geng In order to stream video to your ground control station you can do something similar to the following
        ffmpeg -an -sn -f rawvideo -pix_fmt nv21 -s:v 640x480 -i /opt/frame0 -f mpegts udp://GCS_IP:4242
        Where GCS_IP is the IP address of the ground control station (laptop) that you are connecting to.
        • Eric KatzfeyE
          Eric Katzfey ModalAI Team
          Also, you have to start the camera application that creates /opt/frame0 before starting the docker. Otherwise the docker will create /opt/frame0 itself as a directory and not as a pipe. If this happens, exit the docker, delete /opt/frame0, start the camera application, then start docker.
          • Ruijie GengR
            Ruijie Geng
            Thank you! I will have a trial to do that!
            • Ruijie GengR
              Ruijie Geng
              I meet another question that I try to run hello_hal3_camera -l /dev/frame0 before starting docker, but gives the error
              ~ # hello_hal3_camera -l /dev/frame0
              Camera id: 0
              Image width: 640
              Image height: 480
              Number of frames to dump: 0
              Frame FIFO: /dev/frame0
              Camera mode: preview
              SUCCESS: Camera module opened
              Camera Id: 0 Facing: 0
              Camera Id: 1 Facing: 1
              Error: Could not open named FIFO /dev/frame0
              Camera Id: 2 Facing: 1
              Camera HAL3 test is now running
              • Eric KatzfeyE
                Eric Katzfey ModalAI Team @Ruijie Geng
                @Ruijie-Geng Can you please show the output of "ls -l /dev/frame0"?
                • Ruijie GengR
                  Ruijie Geng
                  Sorry for the late reply. I try the code again, the bug is gone. I can open /dev/frame0 correctly.
                  Thank you very much
                  • Ruijie GengR
                    Ruijie Geng
                    Hello, I can use FFmpeg to stream the data from /opt/frame0. And I can view something on my laptop. But the stream is something with green background. Do you meet a similar issue before?
                    Does something wrong with my camera or the type of visual stream is not correct?
                    • Eric KatzfeyE
                      Can you please send us the output of "ls -l /dev/frame0", the output showing hello_hal3_camera, and also ffmpeg?
