  2. VOXL SDK and Software
  3. Example to stream video via ffmpeg
9 Posts 3 Posters 2.8k Views 3 Watching
  • Ruijie GengR Offline
    Ruijie Geng
    In this documentation(https://docs.modalai.com/docker-on-voxl/#access-to-mipi-cameras), last part, I get this code
    ffmpeg -an -sn -f rawvideo -pix_fmt nv21 -s:v 640x480 -i /opt/frame0 <output options>
    I already set up the docker with roskinetic-xenial_v1_0. Would you like to give an example to use FFmpeg? I want to stream the visual data and view such data on my laptop.
    I tried to save the video locally. but the system give me error
    ffmpeg -an -sn -f rawvideo -pix_fmt nv21 -s:v 640x480 -i /opt/frame0 output.mov
    /opt/frame0: Is a directory
    Thank you!
    • tomT Online
      tomT Online
      @Ruijie-Geng In order to stream video to your ground control station you can do something similar to the following
      ffmpeg -an -sn -f rawvideo -pix_fmt nv21 -s:v 640x480 -i /opt/frame0 -f mpegts udp://GCS_IP:4242
      Where GCS_IP is the IP address of the ground control station (laptop) that you are connecting to.
      • Eric KatzfeyE Online
        Also, you have to start the camera application that creates /opt/frame0 before starting the docker. Otherwise the docker will create /opt/frame0 itself as a directory and not as a pipe. If this happens, exit the docker, delete /opt/frame0, start the camera application, then start docker.
          Ruijie Geng
          Thank you! I will have a trial to do that!
            Ruijie Geng
            I meet another question that I try to run hello_hal3_camera -l /dev/frame0 before starting docker, but gives the error
            ~ # hello_hal3_camera -l /dev/frame0
            Camera id: 0
            Image width: 640
            Image height: 480
            Number of frames to dump: 0
            Frame FIFO: /dev/frame0
            Camera mode: preview
            SUCCESS: Camera module opened
            Camera Id: 0 Facing: 0
            Camera Id: 1 Facing: 1
            Error: Could not open named FIFO /dev/frame0
            Camera Id: 2 Facing: 1
            Camera HAL3 test is now running
            • Ruijie GengR Ruijie Geng
              Camera id: 0
              Image width: 640
              Image height: 480
              @Ruijie-Geng Can you please show the output of "ls -l /dev/frame0"?
                Ruijie Geng
                Sorry for the late reply. I try the code again, the bug is gone. I can open /dev/frame0 correctly.
                Thank you very much
                  Ruijie Geng
                  Hello, I can use FFmpeg to stream the data from /opt/frame0. And I can view something on my laptop. But the stream is something with green background. Do you meet a similar issue before?
                  Does something wrong with my camera or the type of visual stream is not correct?
                    Can you please send us the output of "ls -l /dev/frame0", the output showing hello_hal3_camera, and also ffmpeg?
