  3. PX4 -> QGC connection through USB for VOXL2
27 Posts 8 Posters 4.3k Views 4 Watching
  • Q qt
    [[topic:post-is-deleted]]
    Q Offline
    Q Offline
    qt
      @Sarika-Sharma ,
      We discussed this internally and we will make an effort to formalize enabling the instructions (in a script) in the near future, but there is a relatively short way of enabling TCP/IP communication between VOXL2 and a QGC host. Please try these instructions and let us know if that works for you or what issue you run in to.
      Basically, there is a command to enable the usb gadget in the kernel and this creates the network interface which you then have to configure on both sides. You can change the IP range if necessary.
      # VOXL2 Setup
      # Begin by configuring the usb gadget
      sed -i '/ln -s functions\/ffs.adb configs\/c.1\/f2/a \ ln -s functions\/ncm.0 configs\/c.1\/f3 2>\/dev\/null | true' /sbin/usb/compositions/901D
      # Next setup a udev rule to give our NCM device a static IP (192.168.7.2)
      echo 'ACTION=="add", SUBSYSTEM=="net", KERNEL=="usb0", RUN+="/bin/sh -c '"'"'sleep 2; /sbin/ifconfig usb0 192.168.7.2 netmask 255.255.255.0 up'"'"'"' > /etc/udev/rules.d/80-usb-ncm.rules
      # Reboot VOXL2
      # Check usb0 network device
      voxl2:/$ ifconfig usb0
      usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
              inet 192.168.7.2  netmask 255.255.255.0  broadcast 192.168.7.255
              inet6 fe80::935f:1a09:ab1d:d2fb  prefixlen 64  scopeid 0x20<link>
              ether 56:77:2d:6c:84:9b  txqueuelen 1000  (Ethernet)
              RX packets 0  bytes 0 (0.0 B)
              RX errors 0  dropped 0  overruns 0  frame 0
              TX packets 0  bytes 0 (0.0 B)
              TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
      # Host Side Configuration
      - note that a network manager may rename the device from usb0 to something else..
      ifconfig usb0
      usb0: flags=4098<BROADCAST,MULTICAST>  mtu 1500
              ether fa:74:5a:f3:2b:88  txqueuelen 1000  (Ethernet)
      #bring up the interface and set it to static ip
      sudo ip addr add 192.168.7.1/24 dev usb0
      sudo ip link set usb0 up
      # Can also use Network manager to configure the network interface for a static configuration
      - address 192.168.7.1
      - netmask 255.255.255.0
      - gateway 192.168.7.1
      # ping VOXL2 from linux host
      - ping 192.168.7.2
      #set up QGC
      - use ip address:port : 192.168.7.2:14550
      You can also use other network tools like ssh, etc, to communicate to the host, but this setup does not enable you to communicate from VOXL2 to outside world (using NAT to enable internet access via the host)
      Q Offline
      Q Offline
      qt
      @Alex-Kushleyev
      That's not perfect but I created a shell script based on https://docs.modalai.com/qgc-via-adb/ for the drone configuraiton.
      For my PC configuration, I created an udev rule to force an interface name since usb0 is renamed in "enx******". My udev rule can only work with my drone (I think). To define IP address, I add a conf file in /etc/systemd/network/
      I have only tested on my linux and it works perfectly :
      #!/usr/bin/env bash
      set -euo pipefail
      # See ModalAI doc : https://docs.modalai.com/qgc-via-adb/
      UDEV_RULE_DRONE="/etc/udev/rules.d/80-usb-ncm.rules"
      UDEV_RULE_PC="/etc/udev/rules.d/99-voxl-usb-ncm.rules"
      SYSTEMD_CONF_PC="/etc/systemd/network/10-voxl0.network"
      USB_COMP_QUALCOM="/sbin/usb/compositions/901D"
      # Network configuration
      USB_IFACE="usb0"
      USB_NET="192.168.7.0/24"
      PC_IP="192.168.7.1"
      DRONE_IP="192.168.7.2"
      NM_CONN_NAME="voxl-usb-ncm"
      show_help() {
          echo "Usage: $0 [--pc] [--drone] [--uninstall]"
          echo
          echo "Enable USB NCM networking for ModalAI VOXL / Starling 2 Max"
          echo
          echo "Options:"
          echo "  --pc         Configure host PC only"
          echo "  --drone      Configure drone via adb only"
          echo "  --uninstall  Remove configuration"
          echo "  --help       Show this help"
          echo
          echo "Defaults: if neither --pc nor --drone is provided, both are processed."
      do_pc_install() {
          echo "[INFO][PC] Installing udev rule for VOXL USB NCM"
          cat > "$UDEV_RULE_PC" <<EOF
      SUBSYSTEM=="net", ACTION=="add", ATTRS{idVendor}=="05c6", ATTRS{idProduct}=="901d", ATTRS{serial}=="890d035c", NAME="voxl0"
      EOF
          echo "[INFO][PC] Creating systemd-networkd config for voxl0"
          cat > "$SYSTEMD_CONF_PC" <<EOF
      [Match]
      Name=voxl0
      [Network]
      Address=${PC_IP}/24
      LinkLocalAddressing=no
      IPv6AcceptRA=no
      EOF
          echo "[INFO][PC] Reloading udev rules"
          udevadm control --reload-rules
          udevadm trigger
          echo "[INFO][PC] Restarting systemd-networkd"
          systemctl restart systemd-networkd
          echo "[INFO][PC] PC installation complete"
      do_pc_uninstall() {
          echo "[INFO][PC] Removing PC configuration"
          if [ -f "$UDEV_RULE_PC" ]; then
            rm -f "$UDEV_RULE_PC"
            echo "[INFO][PC] Removed udev rule"
          fi
          if [ -f "$SYSTEMD_CONF_PC" ]; then
            rm -f "$SYSTEMD_CONF_PC"
            echo "[INFO][PC] Removed systemd-networkd config"
          fi
          udevadm trigger
          echo "[INFO][PC] PC uninstallation complete"
      do_drone_install() {
          echo "[INFO][DRONE] Enabling USB NCM networking on VOXL via adb"
          adb root
          adb remount
          echo "[INFO][DRONE] Updating USB composition in Qualcomm script \
      $USB_COMP_QUALCOM configure the usb gadget with \
      the addition of the function NCM"
          echo "[INFO][DRONE] In $USB_COMP_QUALCOM, \
      add the line 'ln -s functions/ncm.0 configs/c.1/f3 2>/dev/null | true' \
      just after the line 'ln -s functions/ffs.adb configs/c.1/f2'"
          adb shell "sed -i '/ln -s functions\\/ffs.adb configs\\/c.1\\/f2/a \
          \\        ln -s functions\\/ncm.0 configs\\/c.1\\/f3 2>\\/dev\\/null | true' \
          $USB_COMP_QUALCOM"
          echo "[INFO][DRONE] Creating udev rule $UDEV_RULE_DRONE for usb0 with IP ${DRONE_IP}"
          adb shell "cat << 'EOF' > $UDEV_RULE_DRONE
      ACTION==\"add\", SUBSYSTEM==\"net\", KERNEL==\"usb0\", \
      RUN+=\"/bin/sh -c 'sleep 2; /sbin/ifconfig usb0 ${DRONE_IP} netmask 255.255.255.0 up'\"
      EOF"
          echo "[INFO][DRONE] NCM enabled — reboot required"
      do_drone_uninstall() {
          echo "[INFO][DRONE] Removing NCM configuration"
          adb root
          adb remount
          echo "[INFO][DRONE] Removing udev rule $UDEV_RULE_DRONE"
          adb shell "rm -f $UDEV_RULE_DRONE || true"
          echo "[INFO][DRONE] Reverting USB composition (901D)"
          adb shell "
          sed -i '/ln -s functions\\/ncm.0 configs\\/c.1\\/f3/d' \
          $USB_COMP_QUALCOM
          echo "[INFO][DRONE] USB NCM configuration removed"
          echo "[INFO][DRONE] Reboot required to fully apply changes"
      # Arg parsing
      TARGET_PC=false
      TARGET_DRONE=false
      DO_UNINSTALL=false
      for arg in "$@"; do
        case "$arg" in
          --help) show_help; exit 0 ;;
          --pc) TARGET_PC=true ;;
          --drone) TARGET_DRONE=true ;;
          --uninstall) DO_UNINSTALL=true ;;
            echo "[ERROR] Unknown argument: $arg";
            show_help;
            exit 1 ;;
        esac
      done
      # Default to both if none selected
      if ! $TARGET_PC && ! $TARGET_DRONE; then
        TARGET_PC=true
        TARGET_DRONE=true
      fi
      # Execute
      if $DO_UNINSTALL; then
        $TARGET_PC && do_pc_uninstall
        $TARGET_DRONE && do_drone_uninstall
      else
        $TARGET_PC && do_pc_install
        $TARGET_DRONE && do_drone_install
      fi
      echo "[INFO] All done."
        Hi All - gonna spend a bit of time looking into this today so I can get some context on the problem.
        Zach
        B Offline
        B Offline
        bendraper
        @Zachary-Lowell-0 Hey Zach did you discover anything in this effort? I played around with recompiling the kernel to include the CONFIG_USB_CONFIGFS_RNDIS=y flag and confirmed it took on my Voxl 2 Mini, and can see the existence of a new rndis.rndis function in the usb gadget functions directory, but when I try to reconfigure the 901D config file, I end up just breaking the USB port entirely.
        • Zachary Lowell 0Z Offline
          Zachary Lowell 0
          @qt said in PX4 -> QGC connection through USB for VOXL2:
          name
          @bendraper I kind of redid exactly what you described above and ran into very similar issue in the sense that it basically rocked my usb-c port. All this to say, I think we should choose a different route - is it possible instead to route the packets via adb over the USB-C port instead to basically get the same result? Point the software to the serial connection and leverage ADB to pull the packets that are forwarded? Basically creating our own sudo rndis connection almost.
          Zach
          B 1 Reply Last reply
            name
            Zach
            B Offline
            B Offline
            bendraper
            @Zachary-Lowell-0 This would probably work but for my use case I cannot guarantee ADB being an option unfortunately.
            • B bendraper
              #26
              @bendraper , have you considered running a docker container (VM) on your Windows machine with a minimal Linux kernel that would use the Linux drivers for NCM and create the proper network connection between VOXL2 and Linux container. Then you could potentially set up the routing table in Windows so that it can access the device via the Linux container and linux container may need to have some networking magic down as well to pass through the communication?
                Zachary Lowell 0
                ^^^ This is the next best option outside of ADB IMO - nice suggestion @Alex-Kushleyev
