  2. VOXL Dev Kits
  3. VOXL Flight Deck
  4. VOXL M500 vision problem!!
Scheduled Pinned Locked Moved VOXL Flight Deck
13 Posts 4 Posters 2.8k Views 3 Watching
  • Vũ Văn LongV Offline
    Vũ Văn Long
    wrote on last edited by Vũ Văn Long
    Hello, me again my voxl m500 frame is driff while fly in position mode Screenshot from 2021-01-20 10-42-11.png
    here is the voxl/vision-px4.conf text. last time after reset the configuration to the factory -> then i also changed the offboard mode to "off" and the m500 can fly in poistion mode but the performance is not good, it's mean sometime the the driff was maintained. i think the problem is not here. (about reset the vision-config to the factory, i just reset and not config anything...
    pls help me!
      Is the tracking camera looking at interesting "features" when it takes off, or is it just white floor? If it can start on a carpet or something, the vision system will have something to track. this will help VIO reduce drift.
        Vũ Văn Long
        it just is a whitle floor like this 140399418_1382482975425604_1999387540459859908_n.jpg
          Can you put some pieces of duct tape on the floor or something to make it more interesting to the VIO system? Especially since it looks like that floor might be reflective. Random small pieces of tape, like electrical or duct tape, would likely help.
          You can monitor the VIO stability on QGC. Those numbers should stabilize after takeoff, but obviously you want them stable on the ground too.
          Vũ Văn LongV 1 Reply Last reply
          • Chad SweetC Chad Sweet
            Vũ Văn Long
            hi, here is the video i just captured https://drive.google.com/file/d/1Am63zD09am8nx_BBpAB2JfTYcf_IFMST/view?usp=sharing
              Vũ Văn Long
              the local NED position is look good at the init state as well as when i move the drone into the other location.
                thanks for sending, I will pass along to someone more familiar. Was this all working before? Do you know what has changed?
                  Vũ Văn Long
                  last week it used to work normally. i did't changed any strange thing, just re-configuration the drone to the factory state. by "voxl-configure-vision-px4 -f" to take again the NED position cuz before that i had config vision lib by "voxl-configure-modalai-vl" and the local poistion is lost.
                    Vũ Văn Long
                    pls help me soon. we can set up an online support via teamview to make the problem more clearly.
                    • James StrawsonJ Offline
                      James Strawson
                      Does this behavior only occur in PX4 position mode? Does it fly in PX4 manual mode?
                        Vũ Văn Long
                        @James-Strawson yes,we only test uav in position mode. we didn't use manual for testing.
                          Please try manual mode. it seems there might be a PX4 parameter mismatch. It would be good to see if the m500 flies properly without VIO.
                          @modaltb Do you have a pointer to the Flight Core factory parmeters?
                          The VIO indoor EKF parameters are here
                            There's a few files (as we use DRY even on params 😉 The procedure to do this is here
                            When you reload the airframe (via these parameters) you'll end up losing calibration and having to go through the calibration process. This is documented here
                            You'll end up loading these, in this order:
                            • configures core airframe for m500 with 4S battery (standard):
                              https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/raw/master/platforms/v1.10/m500_4s_config.params
                            • VIO indoor EKF
                              https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/raw/master/helpers/ekf2_indoor_vio.params
                            • Serial params (to be safe, these should be set by default)
                              https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/mavlink_serial_ports.params
                            • If needed and applicable, radio
                              https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/gimbal_dx8_config.params
