  3. VOXL2 bricked and not entering forced Fastboot
voxl-2
17 Posts 2 Posters 3.6k Views 1 Watching
  • T TPSetati
    Re: VOXL2 bricked
    Good day
    I am facing the bricked VOXL2 issue and forcing fastboot is not working.
    After following the instruction to force a fastboot, I connect the USB cable to the host PC. Running dmesg -wH shows:Screenshot from 2023-04-13 10-02-23.png
    lsusb also confirms the Qualcomm device is connected
    Unfortunately fastboot devices still gives no output
    T Offline
    T Offline
    TPSetati
    wrote on last edited by TPSetati
    Apologies, I realized the error on my part. Here is the correct output
      @TPSetati fastboot devices is the correct command.
      Your VOXL2 seems to be enumerated in QDL mode (factory flash mode).
      There are two ways this happens:
      1. One of the QDL switched is flipped to the ON position (either on VOXL2 itself or on an add-on board). If this is the case, you'll want to flip the switches to the OFF position.
      2. The VOXL2 is bricked, in which case you can follow the instructions here in order to recover it https://docs.modalai.com/voxl2-qdl/
      • T Offline
        T Offline
        TPSetati
        Good day
        Thank you for your response and for showing me another solution to try. I am trying the QDL route, but have hit a speed bump.
        SW2 has been switched to on and the host PC recognizes that the VOXL2 is in QDL mode
        I downloaded the system image on the QDL page and unzipped it. When running the sudo qdl command, nothing happens.
        What could the issue be here?
        T 1 Reply Last reply
        • T Offline
          T Offline
          TPSetati
          When the board is disconnected, the qdl command can detect that nothing is connected Screenshot from 2023-04-17 15-03-44.png
            @TPSetati Maybe modemmanager is interfering?
            sudo systemctl stop ModemManager
            • T Offline
              T Offline
              TPSetati
              I ran thesudo apt remove --purge modemmanager command to uninstall it, but there was nothing to uninstall according to the output
              • T TPSetati
                Good day
                T Offline
                T Offline
                TPSetati
                @TPSetati I am just realizing that the VOXL2 board was already in QDL mode before I switched SW2 to the ON position. Even if I switch it back to off, it remains in QDL mode. Is there another switch that could be causing this?
                  @TPSetati What does your hardware setup look like? Do you have anything else connected to your VOXL2?
                  • T Offline
                    T Offline
                    TPSetati
                    Our setup is similar to that on https://docs.modalai.com/voxl2-d0006/. All of this is on a Sentinel drone.
                      @TPSetati Depending on the sentinel kit it may have an add-on board attached to VOXL2 that has a SW2 switch as well.
                      • T Offline
                        T Offline
                        TPSetati
                        The add-on board we have connected is the WiFi board with its Fastboot button. The only SW2 I have spotted is the one depicted on https://docs.modalai.com/voxl2-qdl/.
                        Before the system image got corrupted, everything worked fine and no buttons or switches were engaged. I am finding it weird that it seems that the board went into EDL mode upon corruption with no changes made to the hardware.
                          @TPSetati Interesting, do you know what happened that caused it to brick?
                          • T Offline
                            T Offline
                            TPSetati
                            We flew the drone and had a semi-hard landing (I say semi-hard because we've had harder landings but the drone got back to flying easily). When we went in to check the drone, nothing was physically damaged. We just noticed that the WiFi was off.
                            We thought cycling the power would work, as it usually did, but this was not the case now. When trying to connect via ADB and noticed it didn't work, that's when we knew something was wrong.
                            We tried fastbooting the board, and that also was not working. So we realized that this problem is deeper than just a bricked board.
                              @TPSetati Yeah it definitely seems like there is some sort of hardware issue. It's possible something has become disconnected or unseated, I would double check all cable connections, camera connections, board to board connections, etc. A semi-connected or incorrectly connected cable / camera / board can cause inconsistent boot or power issues which may be what you're seeing.
                              • T Offline
                                T Offline
                                TPSetati
                                We'll have to take a look on our side then. Could we receive the schematics of the board and perhaps the source code for the qualcomm so we can test?
                                  @TPSetati I'd recommend sending it in to us for an RMA so that we can do an inspection: https://www.modalai.com/pages/rma
