VOXL2 J2 5VDC Fan Control overcurrent
Hi devs
What would happen if i sink more than 400mA on the FAN RETURN pin of J2?
Would i destroy anything on the board?
@hmlow
Yes, you can damage components in the control circuit, then the fan would no longer operate.
The fan we sell is rated for 110mA. You should not need much more than that anyway to have effective cooling. -
@Vinny nah I'm trying to use J2 for smth else. Probably won't draw anything more than 250mA but I just wanted to be sure about what's connected to those pins
@hmlow Please be aware that the fan circuit at the connector uses a switched ground technique with series resistor for monitoring fan speed/tach. The more current you use, the higher the ground offset you'll have. We have not validated that port with anything other than a fan. Using for anything else is at your own risk.
@Vinny may I know what is the value of that series resistor?
I'm using this to power a LED flashlight (only to fully turn on and off, nothing in between). I already have a current limiting resistor for the LED array, but I guess I have to factor in the one that is built directly onto the VOXL2 as well
