<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL2 J2 5VDC Fan Control overcurrent]]></title><description><![CDATA[<p dir="auto">Hi devs</p>
<p dir="auto">What would happen if i sink more than 400mA on the FAN RETURN pin of J2?</p>
<p dir="auto">Would i destroy anything on the board?</p>
]]></description><link>https://forum.modalai.com/topic/2026/voxl2-j2-5vdc-fan-control-overcurrent</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 13:10:20 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2026.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 Apr 2023 12:37:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VOXL2 J2 5VDC Fan Control overcurrent on Tue, 04 Apr 2023 16:59:53 GMT]]></title><description><![CDATA[<p dir="auto">Sure <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/716">@hmlow</a><br />
here is a schematic snippet of that section so you have all the info:<br />
<img src="/assets/uploads/files/1680627538383-7c56d0e9-6cd1-488e-9b30-a189e04b455a-image.png" alt="7c56d0e9-6cd1-488e-9b30-a189e04b455a-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/9474</link><guid isPermaLink="true">https://forum.modalai.com/post/9474</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Tue, 04 Apr 2023 16:59:53 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 J2 5VDC Fan Control overcurrent on Mon, 03 Apr 2023 23:02:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/157">@Vinny</a> may I know what is the value of that series resistor?</p>
<p dir="auto">I'm using this to power a LED flashlight (only to fully turn on and off, nothing in between). I already have a current limiting resistor for the LED array, but I guess I have to factor in the one that is built directly onto the VOXL2 as well</p>
]]></description><link>https://forum.modalai.com/post/9455</link><guid isPermaLink="true">https://forum.modalai.com/post/9455</guid><dc:creator><![CDATA[hmlow]]></dc:creator><pubDate>Mon, 03 Apr 2023 23:02:49 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 J2 5VDC Fan Control overcurrent on Mon, 03 Apr 2023 14:44:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/716">@hmlow</a> Please be aware that the fan circuit at the connector uses a switched ground technique with series resistor for monitoring fan speed/tach. The more current you use, the higher the ground offset you'll have. We have not validated that port with anything other than a fan. Using for anything else is at your own risk.</p>
]]></description><link>https://forum.modalai.com/post/9444</link><guid isPermaLink="true">https://forum.modalai.com/post/9444</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Mon, 03 Apr 2023 14:44:53 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 J2 5VDC Fan Control overcurrent on Sat, 01 Apr 2023 16:02:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/157">@Vinny</a> nah I'm trying to use J2 for smth else. Probably won't draw anything more than 250mA but I just wanted to be sure about what's connected to those pins</p>
]]></description><link>https://forum.modalai.com/post/9436</link><guid isPermaLink="true">https://forum.modalai.com/post/9436</guid><dc:creator><![CDATA[hmlow]]></dc:creator><pubDate>Sat, 01 Apr 2023 16:02:38 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 J2 5VDC Fan Control overcurrent on Sat, 01 Apr 2023 14:30:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/716">@hmlow</a><br />
Yes, you can damage components in the control circuit, then the fan would no longer operate.<br />
The fan we sell is rated for 110mA. You should not need much more than that anyway to have effective cooling.</p>
]]></description><link>https://forum.modalai.com/post/9435</link><guid isPermaLink="true">https://forum.modalai.com/post/9435</guid><dc:creator><![CDATA[Vinny]]></dc:creator><pubDate>Sat, 01 Apr 2023 14:30:28 GMT</pubDate></item></channel></rss>
