    Getting the ulogs
    1094
    • Noe MedranoN
      Noe Medrano
      I have seen a few posts about using adb pull /data/... to get the ulogs. I have tried doing this and I get the error:
      bash adb: command not found
      Q1: What could be causing this error? I am connected via usb and using the adb shell.
      Q2: If I am able to connect via wifi and ssh, is there a similar command that would pull the ulogs via wifi?
      Thanks.
        tom admin
        @Noe-Medrano ADB is a program that can be installed on your host PC:
        https://docs.modalai.com/voxl2-system-image/#missing-adb
          tom admin
          @Noe-Medrano But if you're connected via. wifi you can use SCP
          https://linuxize.com/post/how-to-use-scp-command-to-securely-transfer-files/
          • Noe MedranoN
            Noe Medrano
            I am connected via USB. When I do the adb devices and adb shell all is fine and I can connect to the voxl. When I tried using it with pull is when I got that error.
              tom admin
              @Noe-Medrano Are you running that command outside of adb or inside?
              Noe MedranoN 1 Reply Last reply Reply Quote 0
              • Noe MedranoN
                Noe Medrano @tom
                @tom I think inside.
                So I connect the VOXL2 via USB. Then I do the adb devices. When it shows up, then I do adb shell. At this point is where I tried the adb pull. Is there something else that I have to do in between those two steps?
                I also did the bash after the adb shell then tried the adb pull..
                  tom admin
                  @Noe-Medrano So you'll want to do adb pull before you do adb shell.
                  adb shell brings you onto the VOXL2 itself, whereas adb pull needs to be ran on your host PC.
                  • Noe MedranoN
                    Noe Medrano @tom
                    @tom THANKS!!! Is there a way to get the list of ulogs before it downloads them. That way I can write a script that only pulls on the selected ones? Preferably using wifi. I am looking at SCP right now like you suggested for downloading them via wifi.
                      tom admin
                      @Noe-Medrano One option as seen in this post: https://forum.modalai.com/topic/1524/downloading-px4-ulog-files is to connect to QGC over WiFi and download the log files through there.
                      Otherwise you could see a list of all the log files on target with ls /data/px4/log
                      You could call this command via. adb in one line like adb shell ls /data/px4/log
                      If you your VOXL2 is on the same WiFi network as your host PC you could use scp to pull all log files in one line with something like this:
                      scp -r root@VOXL2_IP:/data/px4/log HOST_PC_DIRECTORY
                      where VOXL2_IP is the IP address of your VOXL2 and HOST_PC_DIRECTORY is the directory on your host pc that you'd like the folder to be copied to
                      Noe MedranoN 2 Replies Last reply Reply Quote 0
                      • Noe MedranoN
                        Noe Medrano @tom
                        Maybe you can help me find an explanation for this. I have been using the mavsdk (python) and the jmavsim. So fart I have been testing my scripts using the jmavsim and QGC. I am able to connect to the "drone" in the sim and view the same files that are listed in QGC. This is with no voxl connected to the computer. So as I was looking for away to connect to the voxl and download the ulogs. I did not change any code on python scripts. The voxl happened to be powered and the wifi antenna connected. So my scripts connected to the voxl instead of the simulator.
                        When I was working with the sim only i was using the following to connect to the "drone".
                        drone = System()
                        await drone.connect(system_address="udp://:14550")
                        I have made no changes to my python scripts. Is there something in the voxl or the mavsdk that would connect it to the voxl's wifi instead of the sim? The IP of the voxl is nowhere in my code nor connected to the computer. Before I connect to the drone the following is code appears.
                        async def launch_px4():
                            # Launch the PX4 simulator
                            px4_directory = '/home/nm/dev/PX4-Autopilot'
                            run_px4 = f'cd {px4_directory} && HEADLESS = 1 make px4_sitl jmavsim'
                            px4_process = subprocess.call(['gnome-terminal', '--', 'bash', '-c', run_px4])
                            return px4_process
                        I am just trying to understand what is happening so I know how to edit and create what we need.
                        Thanks.
                        btw, all your suggestions are working. Thank you.
                          tom admin
                          @Noe-Medrano I'd recommend starting a new thread for this topic, that way our entire dev team will get eyes on it
                          • Noe MedranoN
                            Noe Medrano @tom
                            @tom if I use scp to get the file from the drone, how an I specify a specific file? Write now I have a script that will show me all the logs on the voxl. When I select one of those files I can download them. However, the download right now takes forever over wifi. But when I tested using the scp method it was much faster. Since I need file and destination, is there a way that I can use the index to get the file path on the voxl? I am using mavsdk and their download_log and python code to get the ulogs.
                              tom admin
                              @Noe-Medrano scp is a basic linux utility so you should be able to find solid documentation on it's usage, but you can do the following to download a single file:
                              scp root@VOXL2_IP:/data/px4/log/FILE_NAME HOST_PC_DIRECTORY
