  2. Software Development
  3. GPS-denied Navigation (VIO)
  4. VIO for Outdoors
VIO for Outdoors
Scheduled Pinned Locked Moved GPS-denied Navigation (VIO)
4 Posts 2 Posters 1.4k Views 1 Watching
  • Z Offline
    Z Offline
    zkern5254
    wrote on last edited by zkern5254
    I am going to be using the VIO for outdoor GPS denied flight using a stock m500. The environment will be sunny and have a mix of trees, roadways, and flat patches of grass. From what I'm gathering from reading through some forum posts, the VIO is generally setup for indoor flight out of the box. Is there a configuration that is better suited for outdoor VIO that does 1) handles sunny/well lit areas 2) allows it to pick up more features (maybe lowering the confidence required for something to recognized as a feature.) 3) assumes there are going to be zero indoor flights (as is the case for my vehicles.)
    This is kind of a nebulous post and I apologize for that. For some context, when I flew my vehicle at around 6 feet in a field of rocky soil and patchy vegetation I was able to pick up numerous feature points. Once I got to around 20ft or greater, I lost all feature points. I tried pointing the VIO camera towards trees, rows of new newly growing vegetation, a gravel road and got nothing. I was able to pick up a few points when I pointed the camera towards a barn that was near by (yes I test on a farm.) To my understanding, trees, rocks and vegetation might not be the most robust objects for detecting features but I find it hard to believe that there were zero trackable features. Anyways, any help or ideas would be useful and I can post more info if needed, there's just a little bit of a phase lag (its a long drive out to the farm to collect data.)
      There are tips here: https://docs.modalai.com/flying-with-vio/#troubleshooting-vio
      It is incredibly environment dependent. No guarantees regarding any environment, the more features the better though obviously.
      Watch the qvio-overlay. The quality and number of features are a good indicator as to how well it is going to work
      • Z Offline
        Z Offline
        zkern5254
        Yes, understood and that's part of the answer I expect. My bigger question though is if there is a way to tune the feature detection algorithm and or camera settings to be better suited for outdoor GPS denied flight.
          You can't really tune the feature detection algorithm.
          You can tune the exposure algorithm. You might try to increase ae_msv parameter in camera-server config to maybe add more contrast?
