  3. Same hires cam part number but different FOV?
13 Posts 2 Posters 1.3k Views 1 Watching
  • H Offline
    H Offline
    hmlow
    Hi devs
    I've noticed something strange.
    I have a VOXL1 and VOXL2 setup, and both are connected with the hires camera (both has M0025-2 printed on its flex cable). Both setups have hires, tracking and ToF.
    With the exception of camera_id, both have identical config values under "hires" in voxl-camera-server.conf.
    But the field of view looks different. VOXL2 on the left, VOXL1 on the right. Screenshots are taken from the voxl webportal.
    I have not tried swapping the cameras around because the VOXL1 is very tightly integrated into an aircraft already.
    Wanted to check if this is a known issue due to how the hires is handled differently on the VOXL2 or might this be a hardware/lens issue?
      Are you sure they both have M0025-2? M0025-1 has a wider FOV, but did not work well for longer distances. Consequently we changed over to M0025-2 for a longer focal length on newer products
      H 4 Replies Last reply
      • Chad SweetC Chad Sweet
        H Offline
        H Offline
        hmlow
        wrote on last edited by hmlow
        @Chad-Sweet said in Same hires cam part number but different FOV?:
        Yes im quite certain both have M0025-2 as shown:
        alt text
        I also have M0025-1 (the area around the lens is silver unlike the M0025-2 is entirely black in color), but it is not used in this case.
        Do you not observe any change in FOV when swapping your M0025-2 from VOXL1 to VOXL2?
          H Offline
          H Offline
          hmlow
          I made some comparison against the VOXL1 setup that im familiar with.
          On VOXL1, voxl-camera-server -l shows the following for the hires (M0025-2):
          Stats for camera: 0:
                  4208x3120, 4096x2160, 2104x1560, 1920x1080, 1280x720, 2104x1506,
          ANDROID_SCALER_AVAILABLE_PROCESSED_SIZES:
                  4160x3120, 4056x3040, 4000x3000, 3040x3040, 3016x3016, 3840x2160, 3648x2736, 3264x2448,
                  3200x2400, 2976x2976, 3044x1720, 2704x2028, 2704x1520, 2592x1944, 2688x1512, 2028x1144,
                  2160x2160, 1920x2160, 1920x1920, 1880x1880, 2048x1536, 1920x1440, 1920x1080, 1600x1600,
                  1600x1200, 1520x1520, 1440x1080, 1080x1080, 1280x 960, 1340x 760, 2560x 800, 1280x 800,
                  1280x 400, 1280x 768, 1280x 720, 1200x1200, 1280x 640, 1280x 480, 1040x 780, 1024x 768,
                   960x 960,  720x 720,  800x 600,  960x 720,  848x 480,  858x 480,  864x 480,  800x 480,
                   720x 480,  640x 480,  640x 240,  640x 360,  480x 640,  480x 480,  480x 360,  480x 320,
                  min = 41
                  max = 3987
                  332
                  min = 20678ns
                  max = 683881516ns
          On VOXL2, voxl-camera-server -l shows the following for the hires (M0025-2):
          Stats for camera: 2:
                  4208x3120, 4096x2160, 2104x1560, 1920x1080, 1280x 720,
                  min = 54
                  max = 431
                  431
                  min = 15723ns
                  max = 683714540ns
          On both VOXL1 and VOXL2 setups i have the ToF, hires and tracking.
          Both runs voxl suite 0.9
            H Offline
            H Offline
            hmlow
            @Chad-Sweet would appreciate it if you could take a second look at this pls
              H Offline
              H Offline
              hmlow
              @Chad-Sweet
              i investigated deeper. Im somewhat certain that the "loss of FOV" is a software/driver issue - nothing to do with the actual hardware.
              Picture tells a thousand words - pls refer to the various resolutions used on VOXL2 and VOXL1.
              On VOXL2 It seems that i am able to get the full HFOV if the aspect ratio is 1.777 (1280 divide by 720) although the VFOV is still "missing".
              But with aspect ratio of 1.333 (640 x 480 and 1280 x 960), i lose both HFOV and VFOV.
              This is in contrast to the full H and VFOV that i can get on VOXL1 even when the aspect ratio is 1.333 (640 x 480)
              Could it be related to the "missing" ANDROID_SCALER_AVAILABLE observation in the earlier post above? Im running SDK 0.9
                The ISP is configured differently between the two chipsets. There's no right or wrong way to do cropping. It seems you could use an aspect ratio that works well for what hat you are trying to achieve and crop in software to what you would like
                H 2 Replies Last reply
                  H Offline
                  H Offline
                  hmlow
                  @Chad-Sweet
                  Yes i could crop in software to get what i need, but i believe that the camera server first has to output the "full FOV" without cropping away the vertical FOV?
                  If you could refer to the bottom two pictures - the HFOV are the same but the VFOV for the VOXL2 is narrower - possibly cropped away.
                  I am unable to find a resolution/aspect ratio that outputs the full FOV the way VOXL1 did. Could you advise how to?
                    H Offline
                    H Offline
                    hmlow
                    #9
                    @Chad-Sweet
                    And to highlight the downstream impact:
                    If i were to still go ahead with 1280x720 (despite missing VFOV), due another issue on voxl-streamer that incorrectly flattens the output (you can read about this bug HERE, what voxl-streamer eventually outputs look like this extremely elongated/flattened monstrosity :
                    I would greatly appreciate it if the devs could look into this issue as it affects the entire hires streaming functionality.
                      The latest software on dev supports an updated streaming capability with h264 encoding performed in the hardware using OMX inside of voxl-camera-server
                      see this doc on voxl-streamer config
                      this doc on hires_stream output
                        H Offline
                        H Offline
                        hmlow
                        This is great news!
                        Appreciate the update!
                          H Offline
                          H Offline
                          hmlow
                          @Chad-Sweet how can I update just the voxl-camera-server and voxl-streamer and their dependencies to obtain this fix without having to update the entire sdk from the dev branch?
                            That is not really possible, there are too many interdependencies
