  3. UVC Camera interfacing in version 3.2.0
5 Posts 3 Posters 994 Views 2 Watching
  • Dean FortierD Offline
    Dean Fortier
    Hi Modalai Team,
    I am using a UVC camera and following the UVC streaming guide with VOXL version 3.2.0 and do not have ffmpeg installed by default and the link to download the ffmpeg ipk is broken. What is the recommended path forward for using a UVC camera? Should I use voxl-docker-ffmpeg, build voxl-ffmpeg, or something else?
    Also here is my current voxl-version:
    system-image:    ModalAI 3.2.0 BUILDER: ekatzfey BUILD_TIME: 2021-02-05_19:54
    kernel:          #1 SMP PREEMPT Fri Feb 5 20:03:22 UTC 2021 3.18.71-perf
    factory-bundle:  1.0.1 (Yocto installation)
    architecture:    aarch64
    processor:       apq8096
    os:              GNU/Linux
    voxl-suite:
    Package: voxl-suite
    Version: 0.3.4
    Depends: voxl-utils (>= 0.6.0), libmodal_json (>= 0.3.4), libmodal_pipe (>= 1.7.8), librc_math (>= 1.1.4), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.1), opencv (>= 4.5.1), openmp (>= 10.0.1), voxl-camera-server (>= 0.5.6), voxl-dfs-server (>= 0.0.7), voxl-docker-support (>= 1.1.1), voxl-gphoto2 (>= 0.0.5), voxl-hal3-tof-cam-ros (>= 0.0.5), voxl-imu-server (>= 0.7.8), voxl-modem (>= 0.11.0), voxl-mpa-tflite-server (>= 0.0.2), voxl-mpa-tools (>= 0.1.6), voxl-nodes (>= 0.1.3), voxl-qvio-server (>= 0.2.1), voxl-rtsp (>= 1.0.3), voxl-streamer (>= 0.2.1), voxl-vision-px4 (>= 0.8.1), voxl-vpn (>= 0.0.3)
    Section: base
    Architecture: all
    Maintainer: james@modalai.com
    MD5Sum: e1e5bf1a125affe5036099f6ce895bed
    Filename: voxl-suite_0.3.4.ipk
    Description: meta-package for voxl-suite stable release
    Installed-Time: 13238
    Package: voxl-suite
    Version: 0.2.0
    Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
    Section: base
    Architecture: armv7a
    MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
    Filename: voxl-suite_0.2.0.ipk
    Description: meta-package to install all of the voxl-suite
    • A Offline
      Arrowtec
      @Dean-Fortier personally I use the docker version and it works fine on my end
      • Eric KatzfeyE Online
        voxl-streamer is the recommended approach. Documentation for that is here: https://docs.modalai.com/voxl-streamer/
        You can also run ffmpeg in a Docker to access a UVC camera.
          Dean Fortier
          Thank you both
            gstreamer in a Docker also works
