<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UVC Camera interfacing in version 3.2.0]]></title><description><![CDATA[<p dir="auto">Hi Modalai Team,</p>
<p dir="auto">I am using a UVC camera and following the <a href="https://docs.modalai.com/uvc-streaming/" rel="nofollow ugc">UVC streaming guide</a> with VOXL version 3.2.0 and do not have <code>ffmpeg</code> installed by default and the link to download the <a href="http://voxl-packages.modalai.com/dev/ffmpeg_4.2.2_r1_8x96_202006301746.ipk" rel="nofollow ugc">ffmpeg ipk</a> is broken. What is the recommended path forward for using a UVC camera? Should I use <a href="https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-ffmpeg" rel="nofollow ugc">voxl-docker-ffmpeg</a>, build <a href="https://gitlab.com/voxl-public/other/voxl-ffmpeg" rel="nofollow ugc">voxl-ffmpeg</a>, or something else?</p>
<p dir="auto">Thanks</p>
<p dir="auto">Also here is my current <code>voxl-version</code>:</p>
<pre><code class="language-shell">--------------------------------------------------------------------------------
system-image:    ModalAI 3.2.0 BUILDER: ekatzfey BUILD_TIME: 2021-02-05_19:54
kernel:          #1 SMP PREEMPT Fri Feb 5 20:03:22 UTC 2021 3.18.71-perf
architecture:    aarch64
processor:       apq8096
os:              GNU/Linux
voxl-suite:
Package: voxl-suite
Version: 0.3.4
Depends: voxl-utils (&gt;= 0.6.0), libmodal_json (&gt;= 0.3.4), libmodal_pipe (&gt;= 1.7.8), librc_math (&gt;= 1.1.4), libvoxl_io (&gt;= 0.5.4), mavlink-camera-manager (&gt;= 0.0.1), opencv (&gt;= 4.5.1), openmp (&gt;= 10.0.1), voxl-camera-server (&gt;= 0.5.6), voxl-dfs-server (&gt;= 0.0.7), voxl-docker-support (&gt;= 1.1.1), voxl-gphoto2 (&gt;= 0.0.5), voxl-hal3-tof-cam-ros (&gt;= 0.0.5), voxl-imu-server (&gt;= 0.7.8), voxl-modem (&gt;= 0.11.0), voxl-mpa-tflite-server (&gt;= 0.0.2), voxl-mpa-tools (&gt;= 0.1.6), voxl-nodes (&gt;= 0.1.3), voxl-qvio-server (&gt;= 0.2.1), voxl-rtsp (&gt;= 1.0.3), voxl-streamer (&gt;= 0.2.1), voxl-vision-px4 (&gt;= 0.8.1), voxl-vpn (&gt;= 0.0.3)
Section: base
Architecture: all
Maintainer: james@modalai.com
MD5Sum: e1e5bf1a125affe5036099f6ce895bed
Filename: voxl-suite_0.3.4.ipk
Description: meta-package for voxl-suite stable release
Installed-Time: 13238
Package: voxl-suite
Version: 0.2.0
Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
Status: unknown ok not-installed
Section: base
Architecture: armv7a
MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
Filename: voxl-suite_0.2.0.ipk
Description: meta-package to install all of the voxl-suite
]]></description><link>https://forum.modalai.com/topic/194/uvc-camera-interfacing-in-version-3-2-0</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 03:37:02 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/194.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Apr 2021 17:28:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UVC Camera interfacing in version 3.2.0 on Wed, 14 Apr 2021 01:10:08 GMT]]></title><description><![CDATA[<p dir="auto">gstreamer in a Docker also works</p>
]]></description><link>https://forum.modalai.com/post/890</link><guid isPermaLink="true">https://forum.modalai.com/post/890</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Wed, 14 Apr 2021 01:10:08 GMT</pubDate></item><item><title><![CDATA[Reply to UVC Camera interfacing in version 3.2.0 on Tue, 13 Apr 2021 21:18:50 GMT]]></title><description><![CDATA[<p dir="auto">Thank you both</p>
]]></description><link>https://forum.modalai.com/post/889</link><guid isPermaLink="true">https://forum.modalai.com/post/889</guid><dc:creator><![CDATA[Dean Fortier]]></dc:creator><pubDate>Tue, 13 Apr 2021 21:18:50 GMT</pubDate></item><item><title><![CDATA[Reply to UVC Camera interfacing in version 3.2.0 on Tue, 13 Apr 2021 14:53:19 GMT]]></title><description><![CDATA[<p dir="auto">voxl-streamer is the recommended approach. Documentation for that is here: <a href="https://docs.modalai.com/voxl-streamer/" rel="nofollow ugc">https://docs.modalai.com/voxl-streamer/</a></p>
<p dir="auto">You can also run ffmpeg in a Docker to access a UVC camera.</p>
]]></description><link>https://forum.modalai.com/post/888</link><guid isPermaLink="true">https://forum.modalai.com/post/888</guid><dc:creator><![CDATA[Eric Katzfey]]></dc:creator><pubDate>Tue, 13 Apr 2021 14:53:19 GMT</pubDate></item><item><title><![CDATA[Reply to UVC Camera interfacing in version 3.2.0 on Tue, 13 Apr 2021 10:54:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dean-fortier" aria-label="Profile: Dean-Fortier">@<bdi>Dean-Fortier</bdi></a> personally I use the docker version and it works fine on my end</p>
]]></description><link>https://forum.modalai.com/post/886</link><guid isPermaLink="true">https://forum.modalai.com/post/886</guid><dc:creator><![CDATA[Arrowtec]]></dc:creator><pubDate>Tue, 13 Apr 2021 10:54:11 GMT</pubDate></item></channel></rss>
