    How can I upload a python code to my m500 with voxl mavsdk
    355
    • J
      José Quintanilla
      So I recently was able to use the sdk function on my m500 drone, and I want to modify one of the codes in my computer and then try it on my drone, but I don't really know how to upload the new code to the docker image, Does anyone know how to do it?
      • T
        tom admin
        @José-Quintanilla You'll want to mount whatever directory or files you want inside the container using something like: docker run -v /host/directory:/container/directory
        J 1 Reply Last reply 3 Mar 2023, 01:15 Reply Quote 0
        • T
          tom admin
          @José-Quintanilla https://docs.docker.com/storage/bind-mounts/
          • J
            José Quintanilla @tom
            @tom and I can do that from my computer using the adb shell? Im kinda new at this
            • T
              tom admin
              @José-Quintanilla You'd just modify this command that you're using: docker run -it --rm --privileged --net=host gcr.io/modalai-public/voxl-mavsdk-python:v1.1 /bin/bash
              You can push your script to the VOXL with adb push FILE_NAME PATH_ON_VOXL and then add the -v option to the docker command to point to where the script lives on VOXL and where you'd like it to live inside the docker container
              • J
                José Quintanilla
                I still don't get it
                • J
                  José Quintanilla
                  so instead of docker run -it --rm --privileged --net=host gcr.io/modalai-public/voxl-mavsdk-python:v1.1 /bin/bash it woul be: docker run -v --rm --privileged --net=host gcr.io/modalai-public/voxl-mavsdk-python:v1.1 /bin/bash?
                  • T
                    tom admin
                    @José-Quintanilla No, look at the doc page I sent, you have to specify the location of the file on VOXL and well as where you'd like it to mount inside the container. This is a very common docker use-case and there is plenty of documentation out there to show you how to do it.
                    • J
                      José Quintanilla
                      Hi tom, do you have another source I can look up? I still can't seem to understand how to do it
                      • T
                        tom admin
                        @José-Quintanilla https://www.baeldung.com/ops/docker-mount-single-file-in-volume
                        1 out of 10
