voxl-camera-server and ToF sensor on HW Sensor ID:3
I'm trying to run a ToF sensor instead of the HIRes camera on HW Sensor ID:3 in this configuration but camera server is not recognizing the device sometimes. When I run
voxl-camera-server -lsometimes the camera shows on the device list but other times it does not.
I believe in System Image 1.4.1, ToF has support on all 6 camera interfaces?Thanks
You need to use a supported camera configuration. You cannot plug different sensors into different locations. C6 and C9 are supported for TOF. https://docs.modalai.com/voxl2-camera-configs/
If different sensors are plugged into different locations, undetermined behavior will occur
